Low escape wheel
Ammar
Hello,
I am working on a Citizen 8200a movement that was running slow, I took it apart cleaned it and started putting it back together but the escape wheel decided to troll me and sit lower than the pallet fork and not even reach the bridge and the second wheel.
I checked the pivot,the jewel (which is flush with the face of the plate i thought I somehow have pushed it down but apparently I havent and it's not broken) and the bridge ian't bent and what is annying me is the watch was running.
By the way the main bridge or what ever it's called on this movement is a pain in the neck to put back in place I don't like it.
56 minutes ago, oldhippy said:
Did you remove the end stones if any? If so have you put them back in the right order. I would like to see some photos as I can't remember much about this cal movement, both side of the plates please.
There is no end stones on this movement (I have done this mistake before ^_^)
2 minutes ago, watchweasol said:
Hi Ammar  just a thought  if there are no jewel settings to have moved, Have you fitted the wheel upside down therefore putting the wheel on the wrong plane ?????. I have attached the tech sheet to help you
Hi I fitting the wheel the right way I am sure of that, I have a couple of spare wheels from another movement I'll see if the fit and have a try although the pivits on this wheel looks absolutely fine but I am out of ideas
49 minutes ago, watchweasol said:
Hi Ammar another thought and I have done this my self when rebuilding movements, Is the fork/pallet the right way up if not it would be the same , out of line.
I think you are right on this, or the pivot has been replaced at sometime and slipped in a tad further than was first fitted..
14 hours ago, Ammar said:
Hello,
Sure you got the other wheels in the right way up or in there jewels . Could be tricky to get all pivots in place. And the click is in place on the ratchet wheel.
3 hours ago, Ammar said:
uh um the second wheel pivot snapped on me yea... I hate this movement
Not the easiest to align all pivots on this . Has snapped pivots to. BTW which wheel do you mean? The wheel for the second hand don't have a pivot . Sweep second pinion it's called.  Think it's a spring that holds it down or up .
I meant the wheel that meshes with the escape wheel I was so frustrated when I made that comment didn't think of the terminology (not that I know what it's called any way).
I have another spare movement coming my way hopefully I can get it right this time  ^_^
    • Thanks Geotex, From what I can see the keyless works on mine is completely different to those in the photo, I had a bit of a Google and it looks like it's called a rocking bar?? I can't seem to find a single match online though. As far as the setting lever screw goes, you've just explained what I'm doing wrong and why it was probably left out in the first place. It needs to go in before the bridge 🙃. That's why the hole isn't big enough because it's designed to be smaller to stop the screw falling out until the bridge is removed. Thank you for that! I'll remove the bridge tonight and get it refit.
    • The term "digital transistor" is not a term of art--at least in the modern world.  A lifetime ago, there was such a thing as DTL (Diode Transistor Logic).  Resistors were involved, but I am not aware that they were ever integrated into the transistor package.
    • Update: I posted over on NAWCC and it looks like I melted the fine coil wires where they come into the solder lugs. After dropping the heat way down on my iron and being absurdly careful, I have a humming fork!
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring, since it is still good.  I am awaiting the replacement setting, and will update when I do that. In the mean time, I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
