Glue
markr
I'm sure this has been asked before but I could't find it.  What kinds of glue can you use to reapply hour markers back on?  There are pins on the markers. Do I glue face side or the end of the pins on the back of the face.
Quote
    Glue:  that is a good question!:  i do not use "super  clue" for any thing.  (gets wet and turns white and fails,- for surgery. - use stiches)   epxy in small amounts.   for wood:  "weldwood waterproof powered glue".  for pallet jewels:  shellac.   what do the watch makers use?  vin
I have a little bottle of clear nail-varnish on my table which I use for sealing the edges of dials where the paint is flaking and also to re-stick hour markers. Just a dab on the marker and lower it into place. Alternatively you can re-install the marker dry and dab some thinned nail varnish on the back of the dial where the holes are. This is safer than applying glue on the marker as you risk marking the dial with glue if you don't get it right and it moves around.
Anilv
Super glue is some funky stuff.It works  but I have found that  occasionally  it will  get deposited  by vapor,and that these  can only  be removed  by acetone. Additionally  sometimes  the things you want  to  stick together  don't  and the things you don't  want  to stick  together  do.
    • You need to know at least the basics. Then the questions that You ask will begin to make sense. From what is seen on the video, the gear train and escapement look fine, but the balance doesn't rotate free. I can suppose that the thin gold colored shim that must stay under the balance cock is not in place.
    • Yes, there are a lot of shapes and all of them are used in different cases. The one in Waltham A11 is one of the most spreaded and is what I have shown in the beginning. Of course, the radius of the final curve will depend on the distance between the hole in the stone and the regulator pins on the cock
    • I just found these. They don't really grab my eye at the moment, but having seen the change in some of the watches on here, before & after, the results have been pretty impressive. https://www.ebay.com.au/itm/196382906131?itmmeta=01HXBSJJXDB5J6H916ARJP9PHE&hash=item2db9555713:g:REwAAOSwUNdmOYAZ&itmprp=enc%3AAQAJAAAAwOAlUO3a1pAUX60Y8gUeXMPriraj5e7rkBNH2EA6cIUH7kb7hzoq6jRmOsYOQazk9R%2FteDESr1e50Asabv2tbJyDM%2FVODtmrAScFS4jPhHdgu6Jvt%2BFuRGBijpTkPl4NiK%2FDGr6qztc1Ujb33Tt6YdaUztOH9R1y9XJbwjH0puPDy8m0ilYcal7Vphcp7d59DLtBliNnbqfxfWhxdia2xMRyHYFHzR0Rg7NqB1z4xQGMZb73MAG4QBiF9FMkrII88Q%3D%3D|tkp%3ABk9SR_KuyvnqYw
    • I agree, it's getting harder and harder to find anything that meets the brief other than complete junk, or fake/frankenwatches. I would be in favor of raising the limit so people can continue to enjoy the challenge of resurrecting these low cost watches to their former glory and allowing the watchmaker the ability of practicing new skills without the worry of breaking the bank if all doesn't go to plan. Now all we need to do is settle on a value - maybe base the value on a standard currency so we are all playing by the same rules ($, £, €...?) Unless anyone minds I could start a poll and we could all vote on currency and value... let me know!
    • Same for me, but this is the first time I use the Bestfit. I understand that, for a 17-3/4 caliber, I have to consult page 150, but I can't find any resemblance. Thank you for all your research. I learn a little more each time I use this forum 😀
