Does an automatic watch have to be stopped in order to demagnetize?
However, if all you need to do is remove the battery, why not do that. As well, I don’t think magnetism is that much of an issue with an automatic watch, given that it runs on a small servo motor or a stepper motor.
  • Confused 1
Uhhhhhhh... I'm assuming this is a brain fart... haha
"Brain fart!!!" Brilliant expression :biggrin::unsure::biggrin:
Am I missing something? I've never heard of the term "automatic" used in association with any watch that takes a battery...
And to answer OPs question, I have ran my watches through the demagnetiser running without any apparent ill effect. But you might want to if you can to stay on the safe side
Edited by CaptCalvin
Back to the original question, does an automatic watch need to be stopped in order to demagnetize it. Well, first of all, I do apologize for my brain fart. Somehow my brain mapped the word automatic with electronic and Quartz. Not sure why???
Back to the question. When I demagnetize a watch movement, I always make sure the power is removed as I do not want the magnetic force to somehow scramble the hairspring. Not sure if it would but I do know that when the balance turns to its maximum range and the hairspring has fully expanded, it is at its least tight point and perhaps could be vibrated by magnetism. So I would let the power down on the movement, then demagnetize.
Thoughts?
   as far as i know;   automatic means "auto wind".  AND recently learned : only that mainspring has a clutch  so the winder will not break the main spring.  a good reason to stay with quartz  watches.  vin
I presumed JD was thinking or talking auto quartz movements.
The expression in question applies to me personally, I am glad it dose, since it evidences, I must have a " brain" somewhere. :woohoo-jumping-smiley-emoticon:.
    • First of all, thank you for the pdf file of the book on how to replace a gem. So, if there is a problem with the ruby in the movement, should I buy a new or used movement and replace it? When I watch videos on YouTube of people fixing used watches, I feel like there should be a way to buy a gem. Is there no way to buy it?
    • I suppose @donutdan is not forced to earn his living by repairing watches.  I suppose he does it as a hobby and wants to gain experience, to get better in watchmaking and time is not the issue. Then @donutdan should rather try to repair the damage instead of swap parts from a maybe intact other movement. Swapping parts is not watchmaking. And often swapped parts are not the expected solution of all problems. All mentioned damages are repairable. Frank
    • Yeah I figured that one out when I googled and realized that my spindle is actually from Horia. It's smooth with no screwable cap.
