I took apart my little Meister Anker ladies 17 jewels watch hoping that I could figure out the caliber, but found no markings at all anywhere (apart from "17 jewels"). I found a little spacer under the balance cock though. I only saw that in Russian movements so far.
I tried to copy my favorite oil holder Made in Japan (the one with the black color), I kind of managed to do so, but I made mistakes with both copies, because I dont know how to use the lathe and the tools came with it properly. So I am not entirely happy, additionally the lathe belt snapped and I just had no patience and strength to make another one or glue this one together again tonight. I am going to make another type of holder and the caps for all of them, hopefully some time soon.
Ohh and of course this is 100% pallet wood (see the nail hole?), and converted brass bolts as oil cups from the skip.
Edited by luiazazrambo
The first piece where I made no major mistake(s), almost happy, not entirely, could not make the exact copy, shape a bit different also taller a bit than the original. I learnt that sharp tools cut better.
You would need a copying attachment for that, which is very common in woodwork lathes. But I guess making the same part becomes boring very quickly. Good work really.
Yes I watched several videos about different techniques as how to replicate/copy a workpiece.
One way would be like this:
but there ore other ways. You have to find a way what fits for you. Money, time etc.
Watchmaking, clockmaking, toolmaking, machining, designing, plating, chemistry, electronics, drawing, CADding, 3D printing, photographing... We could add another 250 arts and crafts that are closely related with this forum.
We can't master them all, neither we're Renaissance or Industrial Revolution men inventing something new every day, someone is more versatile, someone more specialized. In my opinion all what matter is that we take genuine pleasure and enrichment from whatever we do while keeping in balance with the rest of our life, if we like to wander from a thing to another, so be it.
My new till for my future watchmakers shop. 🙂 I have to figure out how it works, as you can see it is not fully functional but it seems to have all parts. I love the bell sound when it opens. I don't have the keys. And it counts how many times you opened the lid, 25561 so far. 🙂
Ok, these ones are bergeon compatible oil holders equipped with bergeon agate stone from Cousins. The one on the right hand side is pallet wood the other two are from trees I cut down in the garden a while ago.
I have been busy with something else than watchmaking lately, family and automata. My final project of the online automata course I took. As always 100% pallet wood.
Most entertaining. I have a bunch of scrap pallet wood offcuts, but sadly it seems not enough imagination to make automata with them.
I did build a bunch of fencing, and the gate does move if you push it, does that count?
I think that is because it is Russian. It looks like a Zaria 1509B.1 - I've seen a number of those in Sekonda ladies watches.
The shimming of the balance cock, and that shape of shock spring are very distinctly USSR/Russian.
They seem to run quite well if you clean them carefully.
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&Zaria_1509B_1
Edited by AndyHull
It does Andy. The sea theme was not my idea it was the project the students do at the end of the course. The original one came with a bird, but I wanted a cat and a fish. We have two cats and my daughter loves cats. I place the link to the course here not sure if it works or not: https://www.domestika.org/en/courses/3203-wooden-automata-bring-sculptures-to-life-with-movement/course
As I do woodworking anyway and as I have played with the idea to make automatas in my head for a while before I found the course it did not help an awful lot with my woodworking skills but I loved it regardless. It is good for inspiration and also I wanted to reward the effort to put the course together. It also collects some info about the automata in general. It is well made and probably made for ppl with the basic tool set and knowledge. I saw an example which was made out of cartoon paper not wood.
Well done Andy! I thought it would be Russian but was not sure. I have a number of this watches and one of them even have Zaria written on the dial:
I managed to totally ruin its mainspring as it is very very small and tried to put it back by hand. It did upset me, what was even more disturbing is that the set of mainspring winder I have is totally useless and for as why, well I would need to open a separate topic to explain but it is down to the different profile of the barrel arbor and the winder. I am very very very keen to understand how to use these winders though. At the moment I have the impression that you simply cant... or maybe I am just not experienced enough.
These mainsprings are very fragile. I have managed to successfully do a couple around this size by hand, and completely ruined one. I would suggest that if the mainspring looks clean, it might be best to leave it in the barrel and clean it like that, then oil without removing it, as the risk of insufficient cleaning, or insufficient oiling is less than the risk of damaging it.
Simply popping the lid on the barrel can be tricky, and the barrel arbour is also tiny.
Edited by AndyHull
After carving a cat out of a block of some extra hard pine wood (I think that pallet came from the US.) with a blunt kitchen knife decided to make a whittling knife, my first ever knife. 100% recycled. Again wood is pallet wood, pegs from skip, blade is from a used table saw blade. Not perfect at all, but I am happy. I would need a proper belt sander. I left the markings from the file because i liked it.
  • 2 months later...
Garden, family, holidays, also escaping cats destroying cat flaps... all against watchmaking. Terrible. 🤭 However I managed to do this and that including purchasing my 5th lathe this time a wood turning lathe, i am in the process to build a shed for it hopefully made out of pallet wood. Also started to clean up a tailstock and a 3 jaw chuck for one of the watchmakers lathe:
The chuck is ready and lubricated but the tailstock need polishing and lubrication.
I also got this for educational purpose:
ESA 9158 amazing amazing amazing movement. With discrete electronic components reversing the direction of the power compared it to a "normal" mechanical watch. The balance wheel drives the train! 🙂 New strap and new case fully serviced with a bit of mistake... managed to brake one half of the balance jewel incablock shock spring on the bottom side. I am going to take it once again apart and replace the whole plate. (Is it possible to replace that spring only?) Further issue is that I need a movement ring as this one does not have one. Actually I need 3 of them as two other ESA 9158 are "half ready" and they have no movement rings either. Maybe someone could 3D print them? If I would have the dimensions of course...
This is the shock spring, one which is not broken but from another ESA 9158:
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
    • Hello all, I am working on an older Valjoux Chrono. It doesn't have a stamp on the movement anywhere but I believe it is a Valjoux 72. I installed the train of wheels and they will not turn. The problem appears to be the 4th wheel and the escape wheel are not interfacing correctly. I had to replace both of these parts as the pivots were broken on each. I sourced genuine Valjoux/ETA replacements. I think the problem is with the escape wheel as all the wheels turn perfectly if I remove just the escape wheel.  My question to those with more Valjoux experience is am I mistaken? Is this some other model altogether and I have the wrong part or parts?
    • I would remove the wheels, check for damage and if not damaged, clean.
