Hi, i'm sure I've seen a watch maker pushing in a new mainspring, straight from the surround it come's in, is this correct.?
If so can anyone tell me the right way of doing this...many thanks....Bill
  • Confused 1
You are posting int the wrong forum, should be "watch repair help". Not everyone scans all threads. You can also ask mods to move you posting by clicking "report post" which appears hovering on the share icon top right of any posting.
Edited by jdm
  • Confused 1
Yes you can.
Just make sure you have the spring sitting the correct way round to go in the barrel and set the barell down on a hard surface, place the mainspring inside the barrel still in its holder and find something that is just smaller than the surround to gently push it out.
If its an automatic watch make sure to apply breaking grease to the barrel first.
I forgot to say what type of end is on the mainspring?
If its a T end make sure you have it sitting in the slot when you push it out and for other types make sure the end is placed so it is close to the catch on the barrel wall so the spring does not need to move to far to lock into place, if it has to move too far before it catches it may slip past and not catch.
Yes i made sure the end was seating right its got a barb on the end and it don't have a arber the arber is part of the ratchet wheel
its a EB 8800 cal...got it in okay, just got to try it in the watch.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
    • That Island looks pretty good on the pics I found. Must be nice to live there. Welcome! Are there many watchmakers over there?
    • I believe so. I thought about it the last time.
