I'm as green as they come and need a scrap movement for practice. I scored this on an eBay auction for $0.99 (+ $4.99 shipping, LOL) First inspection shows it not in terrible condition. The balance and escapement move at least, but it doesn't wind (very stiff) and the keyless works are either rusted fast or broken (the stem does not move in or out). I'll be taking this very slowly, since it's educational more than anything else.
Please note the high quality cardboard case ring. ;)
DSC_0012crop.thumb.JPG.4322ad45d2ab0aa95be7b8b2d0c1f5b6.JPGDSC_0011crop.thumb.jpg.b0f0b092a0f855cb671d6732e303deac.jpgDSC_0013crop.thumb.JPG.ed63aefa9f2dae6bbcc4452a687bac8e.JPG
Postage is way too high sometimes. Good buy though, and good luck in repair. If new, photo stages, so you know where that spare piece came from lol. Also careful of low flying parts, if not gentle :)
What I notice on photo's from pocket watches, and from my own pocket watches, is that the second hand is almost always gone or loose...
Strange.
For this one, it seems that the movement is not from the housing? Or am I wrong?
Finally got around to finishing up the pocket watch project. I can say that at least it runs, and remarkably keeps decent time. I took some pictures just so I could reference how the movement went together, but it doesn't do justice to the amount of crud that was in there. All I needed to replace was the crystal, since it came without one, and the hands. I went with what I could find that seemed appropriate to the style. What do you think?
I did take pictures as I dismantled it for reference so I could make sure I got it back together properly. I only struggled at one point when I put in a bushing in the keyless works upside down and the setting lever wouldn't fit.  As for the keyless works, when I first posted, I had assumed the watch was set by the crown only to discover a setting lever under the case when I disassembled it. The original tab that would have protruded was broken off so I had to fudge it until I replace it.
I'll post some intermediate pictures once Mark has the photos completely moved to Amazon Cloud.
  • Similar Content
    • Welcome to the forum. You're best starting with something that you know runs well and keeps good time. That way when you've stripped and service it, any problems are due to something you've done.
    • Welcome to the WRT-Forum! Sorry to say it, but you’re very likely to break or lose something when servicing a wristwatch for the first time — I’ve been there! So, if these watches have any value to you, don’t attempt to service them as a beginner.
    • In writing "shimming the staff" I was alluding to the idea trailed in the above referenced thread of inserting a hair along the staff which, as the discussion there covered,  could result in some eccentricity. By making a (more or less) complete cylinder I was hoping to avoid that problem. Don't tell anyone, but needing a very ductile metal to do this by manipulation at such a small scale, I used a piece of an empty Tomato pureé tube! It occurred to me that the material's ductility(?) would also put less stress on the RT in forming a sufficiently tight seal. Anyway, that's how I avoided the temptation to use glue. No doubt your punctuational response to this confession will be "!!!" !
    • Hi All. I would appreciate some advice for a complete newbie on getting into watch servicing - nothing serious,  just as a fun project. I've got a thing for hand-wound watches and would like to bring an old watch (or two) back to life, so looking to learn to do a strip-clean-oil-assemble cycle.   I've toyed with this idea in the past (years ago) and picked up a couple candidates to learn on, but never found the time for them.  One is an old Ingersoll, swiss-made 17 jewels. It seems to wind and tick. Casing, dial, glass are in great shape, so looks like a good candidate to me for the first service. The other is a Benrus DR23. It winds and makes a few reluctant ticks, but then seems to stop. Casing looks like a complete gonner, and the dial is in pretty poor shape too. If the movement is not broken and just needs a service, I wonder if there's any possibility of getting a cheapo Chinese casing & dial to fit this movement in, or is it extremely unlikely to be the right size?   For a start, I want to strip & assemble a movement, perhaps a dozen times to build up the basic parts handling skills. I see that online advice is to buy a Chinese-made ST36 for this purpose. Can I just go at the Benrus or Ingersoll instead, or does it make more sense to get a cheap ST for this? Thank you.
    • Hi,  I have this vintage Navitimer 806 with a bezel that plays a little bit as shown in this video: https://imgur.com/a/2NjdiF0 How would you fix this? I don't see where a gasket would fit for instance. Also, it seems this issue happens sometimes with older Navitimers.  Thanks
