Hi,
I wanted to repair and service an Omega Seamaster DeVille with a monobloc case. It has a two-piece stem so I pulled the crown.
Turns out I pulled the crown to bits :gym: That has never happened before LOL. The rubber snapped in the process.
Did I just ruin a perfectly fine original crown or can it be fixed?
It just gave way after many years. Replace the gasket if possible and put back together. Put it back together, maybe you will have to slightly press the outer rim of the washers with a staking tool before fitting so that it so slightly widened to make a good fit.
58 minutes ago, oldhippy said:
Just replace it with a new one.
43 minutes ago, Nucejoe said:
New crown.
I would but this is the original signed crown. These are expensive and the watch will be worth quite a bit less if I fit a generic crown.
Can't find a gasket though and a new original crown is 20 GBP. The reference number is the 14915 by the way.
Edited by Nutiborskoku
Added something later
Correct. Beside, a good principle in watchmaking is to repair where possible. Otherwise we could be just called parts swappers.
Would you happen to know where to find a new gasket for the crown?
I didn,t think a new original crown would be this inexpensive.
Regards joe
Regards joe
Yup, it's less than I expected as well. Bought original crowns for 50 GBP before.
@oldhippy, @Nucejoe@jdm thanks for your help!
Note that since this was posted in the correct section you can also rate answers and mark correct on with the panel on the left on any posting.
Neither price is expensive and well worth for a valuable watch.
  • 4 weeks later...
16 hours ago, swisschronic said:
I would say if you are really set on using that particular crown JB weild is worth its weight in watch crowns. Cold weld and a new gasket.
?!? Promising cold weld is the same as promising cold fusion - physics doesn't allow that. Read above to learn how it can be repaired without using gluse.
2 hours ago, swisschronic said:
Jdm I think you mean modify the omega winding stem to get a friction fit right...
No I didn't meant that but never mind, I'm done with this topic anyway.
    • A helpful way in aid of assembly is to place all the wheels in their respective places, place to plate on the top and fit a couple of the nuts onto the pillars. This stops all the wheels wobbling about as they are lightly held by the plate, you can manoeuvre the pivots into their holes, using a tool , usually home made or can be bought on eBay. I made my own. As the pivots align and fall into place screw the nuts down a bit to keep up the tension on the plate untill all wheels are in place then tighten down sufficiently to keep the plate in place whilst checking the end shake on ALL wheels and their location when all is good only then tighten down the plate.
    • I'd say my Pultra 10 lathe. It is just so well made and everything fits so tightly together.
