Hey there,
I have following Issue with my SKX007.
I have replaced the Balance assembley, and it seemed to rung nice. With low Beat error (0.1-0.2ms) and only a few second gain per Day.
But ever so often it jumps to run at between 28000-30000 bph. Losening the Balance Cock, moving it a bit and retightnig it most often solves the Case.
Is it just the Endstones that are dirty? Or may there be another Cause?
Thanks in advance
Can you post timegrapher pictures of when it runs fine and when it doesn't? That probably happens when placed in some positions.
If a fault is at endstone,  variation is most noticable in dial up and down positions.  Hairspring sticking or loose spec of object.
How long will it run at 28000 +? a few seconds?
How often does this occur? once a minute? once every 5 minutes?
Does this happen with the mainspring having a few turns of the ratchet wheel or with just minimal mainspring tension?
Anilv
Unfortunatly I wasn't able to reproduce it yet. Guess its a good thing.
When it occurs, it stays this way, until I manually loosing the balance Cock.
However after inspecting the Haispring again, I found a very small amount of corrosion. I scraped most of it away, and since then I haven't experienced the Issue again. Probably some of the corrosion fell off the spring and got stuck between the Cock and the spring, effectively shortening it.
Thank you for your Tips!
There could be many causes or contributing causes. But I have to agree with yankeedog on this one. If the beat changes dramatically and STAYED at that new speed, it is most likely a fowled hairspring. A drop of oil, perhaps? Mark demonstrated this on one of his videos.
I have experimented with a few different things to clean hairsprings.automotive brake cleaner is a mixed bag.one can will leave residue yielding a sticky hair spring.while the next can will not.results with CRC QD electronic cleaner have been pretty consistent.
5 hours ago, ITProDad said:
Did you ever sort this out?
The actual OP posted above. A bit of ghost catching thread is this one.
Edited by jdm
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
