The following sequence of pictures shows how to disassemble the date mechanism of ETA calibre 2472 and ETA calibre 2474.
Previously I posted a sequence of pictures showing how to disassemble the automatic device of ETA calibres 2472 and 2474 as well as ETA calibres 2450 to 2454. You’ll find the post here.
y4mQoea4sjV2wAtZPPn0WB_VJxwQRr28QJ2H60em
y4mhBtiGOLLi62Nxz7L1dyBm7UWph6G1JA5LoMr4
y4mHDB1G96frgZqcxCDPjAnZUTicVUeNRPZz5dkI
y4mMcuad6mbk_gtdyuWWAyoB9owiEXGNn_ZiB0Vx
y4m2IJo0VaX4HfpaO0wcG7KYmMC2Fndy-PDwn1AN
y4m_Vx7V0ipUVk_kZMUlTGJ4S08QDv6x2aAXrsJH
y4mwzxGUDN2eyLXAwMH0GycwriX02pb6B6mnHMIc
y4m1Kby3nLbous_F8509KkQQ0xWL0RCA1DRA0yf2
y4mRH7dLsZkFcaw5SX6262F_2BoHuAJ7HpIGSAg5
y4mNbqsheM3s-Hc1l0gyUttHGd0Hau42tFKZmN5T
y4mXXQ9mqML5YxWk4OACz5U73-wg9z_Fus9sfwRQ
y4mA7UeQtID2MzOzHQ_FMSwP84iJ6Xz4NxjyS1JU
y4mKV3ElP9D6sUbeS2ZmYyg6d3zU1O4doVW2KGIz
y4muiqCD0P6Uq-pTxJB2cC68mLAZ3nvIlLhRuEtV
y4mfAo7cOY9vrQoc7UU_ocwH09dhPqvzu24aMEg2
y4mlZhLXaKOWC1f8CK_1v1UCwg9TUq4nWzQSmEOX
y4maumXx8IxfLZXLNhhlTA4yQ-mmHC87r9UYHaHG
y4mj5gUo_KRbypJWy1bZo6EweKuerLMEdhkraok9
y4mA3qF3CMpr78UWvCZcdOJ_xLJ3o7LIF74mLXRn
y4mP96pA53hrUiVKwr0kIz2bBT9Fkkpboroctapv
y4mAH49HOfdQqzQHSwyFEPQmEQbIAo_EzSVwagk9
y4mbyLzW1rVfy5R57N2fPbib7_ucv81KON0m7hFS
y4m5btN0ZC314CZBoMPAGPRkZiFI3qzks2PKlprQ
y4myHVnj9aF6AwDEtbeQobH8pl_PpumkRzQcdQQr
y4mlLu1EgU5n_bKBaJnMPEYDVy845RQWX40bFdUo
y4mobP4CbDJUwbnsSyq65voj-OeDhDveQ3s5Ryve
y4mV46V48Zq-Zs5l4QouNe9K7hljxzIIwiezeccX
Great teardown, I really enjoy all your write-ups, in fact I download them and use them to practise my "skills"......thanks for sharing bro
Edited by Watchtime
2 hours ago, HSL said:
Såja, riktigt fina bilder!
Now you can relax and enjoy a Gin & Tonic...
Tack vännen! Sitter med en GT i handen just nu! ^_^
Just the one though. You'll need a steady hand and sharp focus to put it all back together. :P
  • 4 weeks later...
    • Its good to understand how and why demagnetisers work. These two pieces of text explain in basic terms how ferrous metal is affected by magnetism and why they can retain some of those properties.
    • Yeah, agree on the rotation thing - I'll use this as my work beater, and rotate between the others outside of that I think.  The 'problem' is with these that in many cases the parts are worth more separately than in a bad example: assume the bezel, dial and movement the same seller is getting rid of came from the same watch... If he sells them all he'll get a similar price to a really good condition example.  There's a good side to that though - it means you can often find the odd bit you need. And I paid less for this case and crystal assembly than I did for a crystal and dial holding ring I bought for another project, so there's still value to be had occasionally.
    • Cheap ginger counters will tell you if you have radium, but don't waste your money and don't worry about it.
    • Nice rescue. I like when a few with heavy patina are worn in rotation with nicer watches of a collection. Frankens, too so long as they aren’t passed off as something else. My experience with these Seikos is they tended to disintegrate on their own so finding correct parts to put an original together is near impossible…
    • Some answers from my view screwdrivers - if the bodies are ok for you maybe only look at changing the blades if possible, probably 100 and 140 first. loupes - 3-3.5 is what is normally recommended for disassembly and assembly, 10x for inspection  digital microscope - not great for working on movements as there is no depth perception, great for inspection and taking photos to post here 😀 automatic oilers - a bite marmite/vegemite at times, various opinions, some swear by them, some use them only for certain jewel settings others don’t care for them at all. They are not at all necessary, the usual alix etc. ones are fine and you don’t need to spend a fortune. They are very subjective though, you may end up making your own from a needle and peg wood because you like it just so.   can’t help with the Geiger counter, I’m one of the ones who don’t get freaked out about it. There is a legitimate concern, however as long as your not licking the dials/hands, or snorting the degraded old powder you are likely to be absolutely fine.   Tom
