So there is this timex automatic i found online from a reputable seller. I cant find much about it anywhere. Ive been looking for a timex automatic but already have a few watches that look like the marlin. This one is a little different and i like it. Any info would be greatly appreciated
We might be able to provide more info if we could read the number at the bottom of the dial below the 6 o'clock marker.
This would give you the design, mechanism and year.
Edited by AndyHull
They did indeed assemble in Taiwan. I have a couple of late mechanicals that were made in Taiwan.
The dial should also have a model number, but this may be obscured by the case.
I suspect the watch you are looking at is probably an early eighties model.
Here is a rather scruffy example of a Taiwan Timex from 1980 that is sitting awaiting my attention.
The numbers at the bottom are 23429 02580  which you can decode from this site -> https://en.wikibooks.org/wiki/Budget_Watch_Collecting/Timex_date_codes
The last two digits being the year  (1980 in this case).
The watch you linked to above is a much nicer example, but the numbers on that one may be hidden behind the case edge.
Price is not something that tends to be discussed on this forum, but based purely on historic prices for similar aged Timex automatics watches sold on ebay,  you could expect to pay anything from under £5 in a non working condition to somewhere between £20 and £100 (perhaps more if in perfect unused condition), depending on whether it has been professionally serviced, and is running well, and how clean and damage free it is.  It does appear to be an attractive and fairly uncommon example.
If the price is right, then I would go for it. What is the right price however is something only you can decide.
Edited by AndyHull
aside from what already has been posted, I can add the watch movement is a #109  day date. early to mid 1980's is my guess without seeing the dial code. ( it maybe hidden from view )  . Case appears to be stainless steel which is a good thing. the negaitves are the model 109 like other latter produc tion Timex movements are of less quality and prone to parts wearing much faster than those from the 1960's - and 1970's.
the styling f the watch case is often called a TV dial due to well it looks like a TV of the period. The crystal is perhaps the most difficult of all the parts to source.  enjoy the watch and beware of Timex collecting I started with one and have now had thousands!
yes, Timex began to use all stainless steel cases on the Automatics in the late 70's.  But, do you know which model was the very first to have an all stainless steel case and what year it was introduced?
Doesnt seem to have a dial code. Which is disheartening. However it doesnt seem like it is in "fake condition" such as the case is slightly beat up. Why would you put that much effort into faking a watch that you are selling for 25 dollars
So you don't own the watch? But, rather are looking to buy it?
Long story short. I own it. My work colleague is getting married liked the look of a watch similar. Another colleague got the watch for him said it felt weird and asked me to take a look at it
I would say a 1967 Timex 600ft diver maybe.
Sent from my SM-G975F using Tapatalk
  • 7 months later...
There should be a dial code at the base of the 6 hour. the last two digits are the year made.  Not seeing it, my guess is early 1980's Marlin Day Date- 106 movement. That is because I see the wavy lines indicating 'water resistant'.   Not at all rare and very common.
On 5/14/2020 at 3:14 AM, NguyenNgocHai said:
Please tell me what version of this Timex watch and how rare it is?
The dial code (if there is one) may be on the dial in  a position that makes it hidden when the movement is in the case.
In other words, you may need to remove the movement from the case to see it. Watches after 1985 may have a different method of dating them. There is an incomplete list of possibilities here -> https://en.wikibooks.org/wiki/Budget_Watch_Collecting/Timex_date_codes
When I zoom in on your picture above, it says "Taiwan", which suggests, like @JerseyMo stated that it is early 1980s. A nice enough watch, but not particularly rare. The Taiwan produced movements tend to be slightly lesser quality (due to cost cuts in later manufacturing runs to keep them competitive).
Edited by AndyHull
On 8/25/2019 at 2:06 PM, yankeedog said:
Stainless steel case? On a timex? I have never seen such a critter.However If JerseyMo says so, it must be true !
This Timex quartz Q diver's watch also has a stainless case (and would you believe, a screw down back and crown...)
  • Similar Content
    • Hi, Would anybody be able to offer some insight as to a possible solution here? When I first opened this watch a while back I thought it was just the end of the ridge and the 'chrome' that had worn away, but taking a look today I see it's worn away the brass to a reasonable extent. Torque comes on the crown wheel, it lifts up and separates from the winding pinion. Is this just a case of replace the mainplate if I want to keep the watch? All the best, John
    • Thanks. That was easier than I though!
    • Can you not remove the pin from the existing spring and just use that? I think if you did something like this you'd need to make sure the piece you cut off was long enough so the thickness didn't interfere with the stud staying in the hole.
    • Hmm ... I can't find anything with a pin like this. I guess with a lathe I could make the pin, then drill a hole in a regular mainspring and rivet the pin to it. Can't really see me doing that without a watchmaker's lathe, though. Am I going to have to shelve the watch because I can't replace the mainspring? There has to be another way. I wonder if I could cut off the end of the existing spring and use it as a catch for a modern manual-wind spring to hook on to?
    • Восток 2403/581096     So a while back I discovered the website of the Vostok factory. It didn't come up on google but was mentioned in some youtoob video. The information was all in Russian and the English translation wasn't fantastic. The "Put in Basket" button was translated to "Put in Garbage". The prices mentioned were also rather jarring. When looking at this piece the numbers were "Three THOUSAND .... two HUNDRED...." and I was thinking 'aww that's a big number' .... "err rubles". I googled the exchange rate and it turned out to only be 30 something squid, so I put in garbage. The postage said "eight HUNDRED ... and seventy!" and again I was thinking 'aww that's a big number' ... "err rubles". It turned out to only be around 8 quid for international delivery, so I threw in an Amphibia for about five THOUSAND - coz I'm such a big spender. I've replaced the straps on multiple occasions and have been abusing this ever since. Funnily enough fleabay would occasionally have similar models (not the sexy tilted dial) for about double the price. So it appears to be a decent business model. Unfortunately nowadays, and not entirely due to politics, it's gotten trickier to order these. The actual payment would need a slight workaround, and I wouldn't trust the Baltic postmen either (they appear to have a reputation of having sticky fingers). For anyone interested, and the prices would've changed over the years, and I'm not sure if I'm allowed to put url's in comments because I wasn't paying attention when reading the forum rules, is this: https://online.vostokinc.ru
