Destroying a Hairspring
As far as I'm concerned the hairspring is the 'Achilles Heel' of the amateur watch repairer. I can manage most things with a varying degree of ability but the hairspring always seems to be a stumbling block for me anyway. I recently ruined a spring from a 2892.2 movement. Whilst removing the balance complete with bridge the spring caught on the teeth of one of the wheels. Spent hours trying to gently 'smooth' out the distortion. In the end gave up and went for a new one. One question I would like to ask is when ordering a 'Balance Complete' presumably it is the balance wheel with spring attached. On this particular movement the spring is attached to the bridge by a wedge shaped pin which appears to be glued on (see photo sorry about quality) What level  of ability is required to attach the spring to the bridge or should I go for balance spring and bridge which of course more expensive?
I assume you mean 2892-2 movement like the one I'm just working on in the pictures. (This one was heavily oiled.)
Yes the stud is glued into place and are not one of the easiest tasks around. I belive if you orderd a balance complete you will get the balance and the spring with stud already attached.
ETA has a special tool to put the spring into place and adjust it with. But with some skills you can do it with flat tiped tweezers too.
Not the easiest task.
I think the question is, how to remove the stud off of the stud holder and replacement.
Thanks HSL
Iv'e bitten the bullet and found a dealer in the US who sells the complete setup...Teach me to be more careful when removing the balance. Yes it is the same movement in a gold cased Garrard. I think I might purchase another spring and fit it to the bridge as an excercise. So it just pushes in and twists? Some seem to be diagonal to the bridge fixing....
Oof glucydur balance. Not as easy to find as nickel.
7 hours ago, Nucejoe said:
Shamefully I heat the stud with soldering gun, burn the glue, the glue will not conduct heat to HS. Assembly is ,Clean reglue.
I ought to read this again see if I can improve technique.
Thank for sharing HSL.
Haha that's similar to what I do sometimes. Quick and easy way to make sure the spring is in most relaxed state when mounted. As well as easier and more accurate to adjust should it need any. I use glowing hot kanthal wire from my vape mod haha.
    • Post some pictures , some good close ones of the parts you've described.
    • Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. If its a potential problem for amateurs to use then i would prefer not to take the risk .
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
