Mainspring Valjoux 7750
Need to change the mainspring on a 7750 . Do i need to take the complete movement apart. Was some times since working on a valjoux  and i have forgot how it's is . The movement should be serviced recently said the owner. But it won't wind with the rotor  . I looked and i can feel that the mainspring jumps when winding manually. Have had the reverse wheel out but that didn't help. Don't want to take the complete movement apart with the hands and such if i don't have to. Would be great if i just can remove the parts inside the case. But is that possible on a 7750. Or is the chronograph parts in the way and need to be removed.
A recently serviced 7750 with a broken mainspring should raise an eyebrow or two, I would have made a complete overhaul while being at it.
You can access it from the back but the amount of junk you have to take away makes it not worth for example leaving stuff on the train Wheel bridge to cut some work. I guess you already got the service manual but I attache it here anyway just for the public interest ;)
7750 Service Manual.pdf
  • Sad 1
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
    • No problem to replace the setting with the staking set. Press the new setting from inside, use flat face punch with hole. The punch must be wider than the setting, the hole to be as not to press at the stone, but only on the bush. Press by hand until the setting gets flush with the plate surface, so the punch must rest on it.
    • Yes, the arbor usually makes about 3 to 3.5 turns. But usually spring takes 2/3 to 3/4 of the free space in barrel, not 1/2, so take it for the calcullations. This way the change in torque is smaller. I have a picture for You, this one is little older, but no mater
    • I overhauled a ladies Rolex and noticed erratic performance so I stripped in down again and did fault finding. This is what I saw. The lower jewel (the one in the plate) is cracked and the hole is too big. Before discovering this, I stripped down and re-cleaned the main-plate (and parts) by hand with a fine natural fiber brush. I somehow missed the fault the first time and cannot understand how it was still running. Perhaps re-cleaning it dislodged some pieces of the jewel widening the hole? I don't know. Now I need to replace the jewel but don't have a Seitz tool. The Rolex part is 2130-0913 and the top and bottom are the same. The part comes complete in brass setting with KIF elastor spring and cap jewel. Note: I have never replaced a jewel. I do have a good vintage stacking set that I've used quite a bit.  Can I replace using a stacking set? Any suggestions would be greatly appreciated.
