The only sure way is to remove the movement from the case and inspect. It looks like a vintage and possibly glued just a hard push and it will pop out. If the crystal has a lip you will need a crystal lift tool. It is water resistant NOT water proof so it is highly unlikely to have a tension ring crystal.
Thanks clockboy!
On 5/18/2019 at 2:24 PM, oldhippy said:
Try pushing it out with your fingers you will soon find out.  Just be careful.
A faceted crystal has ..faces but not a lip. Seiko did not use glue often, and the crystal will not leave by pushing with a thumb.
Fortunately, Seiko helps watch repairers by classifying and documenting the case construction, here we have an "A" as stamped on the case back. Attached the guide. A good discussion is at https://www.plus9time.com/seiko-case-back-information
BTW, I recommend the OP to use the "Watch Repairs Help & Advice" section when it's repair question like this. One advantage is that there answers can be rated and marked as resolving.
1982.03 Seiko Case Servicing Guide.pdf
THANK YOU oldhippy, this has been very enlightening! And thank you for sharing that manual!
JDM.. Hehe..
To appreciate others you can use the like button on the bottom right of any posting.
Edited by jdm
