Most Useless Watch Tool
jdrichard
14 hours ago, m1ks said:
My guess it that the failure point was the winder shaft. I suspect that realistically, you would have to make that from steel as abs plastic is not robust enough.
Its a neat idea though, but probably requires a little more engineering to get it right.
Where did you get the design?
The failure point was in fact the barrel height, the winder shaft is surprisingly strong, pla, in this case, snaps rather than bends under stress.
The height was too high for the Seiko spring allowing coils to jump over another, combine that with the fact it had been abused a little with a couple of kinks I straightened. It snapped off at the saddle.
The file was from thingiverse. I don't have the link handy though.
Edited by m1ks
Interesting. If the CAD file is in the files on thingiverse, then you could presumably adjust the height of the barrel so it may be possible to fix the issue. I may take a look at this when I get some spare time. If you have the link, that might save me a git of google time.
There's an scad file in there if that's useful?
mainspring_winders.scad
  • 6 months later...
    • Usually the coiled spring contacts the piezo sounder and the finger spring is the ground.
    • So I checked with my friendly local lab supplier and they can supply the following in 2.5 lt bottles: Tetrachloroethylene (B-Dip) - approx £65 Trichloroethylene (one-dip) - approx £43 n-Heptane 99% (Essence of Renata) - approx £35 Hexane - approx £45 I can't import or buy locally the 'real' products, hence the raw chemicals above. What do you think would be my best option? I'm edging towards Trichloroethylene - I know there are greater health risks, but given the very small quantities used for each treatment and 99.99% of the time it will be sealed in a jar, I think any risk is vanishingly small? This is mainly due to its assumed superior cleaning properties, or from the experience of this group, is the extra cleaning noticeable compared to its safer alternatives?
    • Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
