Hello, everyone.
I've read quite a bit about 'Nano Oil.'
Has anyone tried 'Nano Oil' for lubricating a watch?
Or, has anyone got any views?
Hadn't heard of it so I had a quick Google and it seems to be a general purpose oil in a pen type applicator?
I note there are three (at least) oil weight ratings like you'd get with motor oil, now, I don't know the weight ratings of watch oil because they don't list those like motor oils etc but I'd guess it wouldn't be ideal certainly for the high speed low torque pivots but probably OK for things like the barrel arbor?
If you want to try cheaper stuff for practise purposes on your own watches I'd suggest a light machine oil like sewing machine oil or similar for the train wheel pivots and such.
For practise oiling purposes pretty much anything will do to 'get your hand in' but for long term practical use I'd say not.
Hi M1ks is right ok if its your own and old practise movments but on better quality watches definitley not as oils differ in quality and viscosity , and they are mineral or synthetic depending on purpose. I have enclosed the mobius oil chart for you
Moebius Oil_Chart.pdf
If possible, I would suggest sticking to the known brands, since they are likely to be stable and predictable over the 5 years plus, that they are expected to work.
If you cannot get them, or you are not too concerned about the quality of the oil as the watch in question is only a practice piece, then you can use sewing machine oil, hair clipper oil, or something similar. Traditionally they even used whale oil.
Motor oil works on clocks too, but that doesn't mean I would recommend it, but I have used it when there was nothing else to hand.
esslinger.com get the euro pocket oiler, its only $5 and comes with a fitted needle. i only use it for polishing pivots but i think it uses a generic clock oil so should be ok for practice
The subject of lubrication has been covered on many, many occasions on this forum. I prefer Moebius oils because they are a tried and tested lubricant. They are not cheap but a 20ml bottle will lubricate a lot of watches.
  • 3 months later...
I havn,t seen a Nano oil marketted by Famous brands, as investment tends towards ceratinty where the same old story of "NEW & IMPROVED" has traditionally worked for advertisement.
Nano like any other research is market driven, I expect to see Nano automobile engine oils continued development daily, but lets face the facts, would you invest on watch oil?
Best Regards   joe
