Hello Everyone
jmm109
Hello, my name is John and have been semi-retired for 5 years. I have been interested in pocket watches and wristwatches for some time now.  I was trained in high school to be a classic repair shop/jobber machinist and spent my career in the mechanical trades, my last job used cranes to do engine disassembly now in my hobby I use tweezers for disassembly.
 I have learned a great deal from the videos Mark has posted and would like to keep learning new things from the wealth of knowledge possessed by Mark and the members here.
I have recently taken a 2 day pocket watch class (disassembly, cleaning and reassembly) at the NAWCC in Lancaster PA, USA and had a great time, our instructor Drew Zimmerman (CW21) was fabulous. Now I am addicted and buying tools.
Thanks & Stay Safe
    • All I do is use a fine marker (sharpie) to put the service date on the back cover, this way it can be removed with some IPA and does no permanent damage to the watch. I'm in two minds about the whole service marking thing, sometimes it's good/bad to see the markings on the watch case back as you know it's been worked on and vice versa. However, if I took my car in for a service and the mechanic scratched some code into the housing of my engine I wouldn't be too impressed. Hence, I think my sharpie solution is a reasonable compromise.
