recommend a tool for lifting sub dial hands
AP1875
Looking for recommendations for a tool to lift the sub dial hands of chronographs 7750 etc.
I am currently using these Horotec levers, if they hand a bend in them they would be perfect (for me). Does anyone know of any other levers of this size or similar with a bend in, so you can actually lever the hands out? or an alternative tool?
The other Horotec levers I have are too thick to get under the hands.
Edited by AP1875
I've something similar to these which I bought a few years ago on the recommendation of an earlier post to this forum. (Probably other sellers that do the same.)
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F292120239715
Work well for watch hands and small second hands on some of the vintage watches that I've an interest in.
Sent from my moto g(6) play using Tapatalk
For £5 definitely worth trying, thanks
4 hours ago, praezis said:
You already have one of the best tools: the dial itself!
Frank
18 minutes ago, AP1875 said:
Huh?
It works but not on all subhands.  I use a generic lever from Cousisnuk . Need to file them to shape though.
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.  I think its because it gets into their cleaning solutions Mike. Theirs or anyone else's that services the watch next time, or if they need to strip back and rebuild. Could preclean but thats all time for a pro. I thought the idea was for the epilame to create a barrier, a wall between the lubrication and anything else, so the lube cant spread.
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
    • I think attaching a nut to the lid to pull it off is the least destructive, any damage damage on the outside is going to an easier fix than any created when trying to push it out from the inside. Scratching up the inside of the lid , mainspring or arbor bearing will be risk. Just my opinion.
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
