seiko movement?
3 minutes ago, Khronos said:
From my experience, the first number of the case code is the movement caliber.  In other words, 6530.
Yes think your quite right ..
Caliber: 6530
Case number: 5799
Serial number: 5 (1975)  8(Augusti) 0490 (Unique serial number)
6530 is the movement reference number, from my own investigations it was in production from 1982 onwards so your serial number would probably date it to August 1985.
I have a Seiko 6530 - 5760  s/no 502572 so a couple of months newer (less old?).
There are also reference numbers on the dial at 6: 6530 - 4370 these refer to the movement and (I think) the dial, hands etc
thanks to all but it seems the 6530 is impossible to come by.all on e-bay are for case only so need a modern equivalent replacement.any ideas?
I believe the 6530 has been obsolete since the late 90s. An "equivalent replacement" was apparently a Pulsar VX20, however that is now obsolete with no listed replacement as far as I can tell. My 6530 came to me as a non runner but after a bit of attention it is now running fine, but the case, dial and glass are not the best. I can sense a deal forming.....
3 hours ago, TexasDon said:
On this side of the pond they seem to be quite abundant. Here's at least one:
https://www.ebay.com/itm/Seiko-6530A-Quartz-Watch-Movement-with-Dial-and-Hands-For-Parts-or-Repair/113668585813?epid=5004511682&hash=item1a772cf955:g:GGwAAOSweYtbJXps&frcectupt=true
The seller notes that he will ship worldwide.
Seems a bit expensive with the postage, probably cost more than the original was worth! Thanks. B.
44 minutes ago, berniethebolt said:
We are at a crossroads. How do want to run it? My case,dial and hands are very good. I am not after making a killing but I do not want to lose either! Offer me your movement or make an offer for my case etc? B.
My watch owes me £7 plus a battery plus a bit of time. So would £15 inc p&p be any help or if not what would you want for your case etc? My main objective is to try and keep another elderly watch working and hopefully subsequently fund another "resurrection". I will open the case up in the morning and let you have some photos of the movement.
On 3/23/2019 at 8:05 AM, philipk5 said:
Herewith mvt photo:
sorry,before i got your post i bid for and won a movement with case and bracelet (which dont look up to much) for just under a tenner so i will see what transpires when i receive it.i will get in touch either way.thanks for the offer.B.
    • Yes, I was referring to the (jewelled) gear train with HP (most of the time, I use 1300, but when Rolex says 1000, I'll use 1000).
    • did I miss the update of the message of something changing?
    • I suppose it would depend upon what your lubricating with those? for instance what does the manufacturer say about those lubricants? I have a PDF from the manufacture and a rather peculiar statement found on the bottom of the chart. my suspicion is the reason the recommending would be without epilam the HP oils like the spread except when they're in Ruby jewel's with steel pivots. tableEN lubrication 2020.pdf
    • These types of hairsprings become weak with age and very fragile. Which I expect it is that giving you trouble, and that wheel is not the correct one, if it were not bent I don't think the movement would run as the teeth are not the correct height. The problem you have is price which depends on you. It can be repaired but is it worth it to you, because there is little value in the clock. A wheel can be made and hairspring replaced. Or hang on to it and keep looking on ebay which is your best bet for replacement parts or even a complete movement but it will be like finding a needle in a haystack.
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
