Lubricants to use with Rolex 3135
37 minutes ago, rodabod said:
Slightly off-topic: has anyone ever tried Epilame on clock bushes? The oil does tend to creep due to gravity and natural spreading.
I know a guy who does, he does really high end restoration and custom fabrication though. He uses an eye dropper to dose the bushings, probably uses more in Fixodrop value that what most normal clock services would cost!
  • 8 months later...
Hey! It's Halloween, so lets resurrect an old thread!
Epilame- it's expensive. I was going to try and make some myself... Then I discovered this stuff:
"HOROTEC episurf-neo", which is supossed to be the same thing, but it's like 1/10th the cost.
Any comments on it?
Their website looks impressive so does the tech sheet. But can we really trust the product if it's this cheap obviously we should be suspicious.
Then the second link is being irritating because it's not letting me show you the link that I found so you go there in search for Epilame You'll see all the supplies to go with your inexpensive product. Unfortunately no expensive products to compare to.
There isn't any reason why cheaper products especially if they're being sold as a watch product can't work. Then what was interesting is on another watch site and I was thinking it didn't look that inexpensive because their cost was basically twice what is costs here. I think the 50 mL bottle was close to $100. It's one of the interesting problems of online watch supply people that sometimes they're not always that she you need to shop around.
There isn't any reason why other products can't work just as well and conceivably be cheaper. Some of these products are used in industrial applications and they obviously can't be superexpensive.
What would be an interesting experiment to try would be to do it the old-fashioned way sort of. The original product is stearic acid and I read a patent once about vapor application was very very good. There is a cleaning machine out there that's name I can't remember that it actually vaporize stearic acid for applying it to the watch parts. Supposedly with the vapor you get a really thin even coding versus the fluids that if you're not careful they evaporate with time and the concentration changes and you can end up with a thicker coating than you want that may be bad but I don't know how but. I is know I've met people to get really excited about how it's all applied heated treated etc. and dropping apart into the bottle itself is a total sin even though that's a convenient way to do it.
https://www.surfactis.com/en/produits/episurf-2/
https://www.jewelerssupplies.com
Yes, I was looking into (and found a reasonable cost small sample picked out) of Steric acid. The only issue I want resolved is the carrier, and then the concentration in solution.
I want to avoid alcohol, as it would limit use on pallet forks. I believe it is water soluble but that’s not an ideal solvent for steel parts. Acetone may work but I’m not certain. Toluene is on the list too.
The $100 bottle for applying it is another hurdle; but I’ve been working on that and may have a lower cost solution. I know another member here was also working on a home made bottle but I never saw how that turned out. I was thinking a second bottle would be good for dilute oil for reversers too.
I have one of the machines John mentioned above that heats the stearic acid to make a vapor. It works great, but I do in practice use Fixodrop on customer watches. If you want to try the vapor method it just needs to be heated to about 80 degrees C, with the parts in a basket or something not in contact with it, in a container that can be closed. 30 to 60 seconds is enough time.
The first liquid epilame that Moebius marketed was Aretol, which was stearic acid in a solvent carrier. I don't know what the solvent was, but it wasn't alcohol. I have spoken to old watchmakers who mixed their own using pure isopropyl alcohol (99%) mixing 1:100 by weight. I have tried that and find that it leaves a visible film, didn't follow up with different ratios as I have the vapor method and Fixodrop. But if you try it with alcohol don't worry about it melting your shellac, it only needs to be in contact a few seconds. In fact the above machine, the Greiner U2, uses alcohol as the rinse for all the parts. The way it is designed the balance and fork get rinsed by themselves for a short time in fresh alcohol (it distills the alcohol continuously), then dried as the other parts get rinsed and the rinse is drained back into the distiller then regenerates for the final rinse. It's a very cool machine.
I can heat some on a hot plate and see how it does.
I have sample panels of cold rolled steel and titanium I can mess around with, to see how an oil drop holds shape over time.
I think I'll order the acid and play around with it a bit. It seems I have some time as the new oil I ordered has been a week in transit with no expected deliver date... Something up with FedEx lately.
  • 2 months later...
as it would be astronomically expensive to dip your clock plates in you could brush it on. Brush it on both sides of where the pivot goes. Then follow up with a piece of peg wood to clear out the hole and may be just a tiny bit of the countersink. I think that would work it would keep your oil word supposed to be.
Someone had asked about Epilame coating (from ye old Rolex service bulletin):
And I have yet to try mine. I will do on the 565 I need that damn spring replaced and then I'll do the usual suspects and see how it does (Episurf Neo).
I also bought two of the $100 German bottles (for much les than $100 for the pair) out of Germany, but they are being transported via mule team, and they aren't good swimmers at all... Still need screens, but I'm less concerned with that. One will be for Epilame and the other will be for Lubretta.
I thought I posted here and my question disappeared for some reason ? Anyway, thanks Tudor. I hope my Fixodrop will arrive shortly and then I can service my Rolex Submariner. I don't have the specialty bottle but I'll try to improvise something.
    • Just got these good quality diamond files from the bay for Just a fiver, we all love a bargain dont we. Brand names are J.K.Smit  and Triefus, two old diamond tool makers so not cheap crap.
    • Its a touch under ive just remeasured it and added a wrist shot. Unbelievably it was £13  plus 3 postage. You dont find watches that nice for that money every day of the week. Maybe removing the epilame in the oil region improves the purpose of it. We may know very soon as i emailed Episurf 4 hours ago to ask that exact question. 🤞they are happy to provide an answer for us. How do you fancy trying a stearic acid vapour treatment experiment  H .  Shall i have a go this afternoon ?
    • That's the size of my grandfather's Ernest Borel watch. Definitely not a lady's watch! 👍
    • Thanks H It does have a big crown for the watch , it could be considered a ladies watch these days i guess, it measures 33mm case 36mm with that large crown 18mm lug space. A tad small for a guy of today, but still very wearable. The photo was deceptive so here it is adorning my 7 1/4 " wrist. It need some love to make it run better. The hair coils are touching so running a bit fast at the moment,  not caused by magnetism, and maybe just a clean and a service. The dtal is in fantastic shape.
    • That's one beautiful timepiece! Love the big crown in proportion to the case. Perhaps a ladies' watch, but I don't think so. I have a "modern Ingersoll" watch, but it has nothing to do with the original brand (Miyota 9015 movement). Interesting synonym for synthetic oils! 😆 There is, of course, a limit to how large a volume of oil epilame can bind and hold in place. If the oleophobic effect is too strong then it can become a problem. I'm not sure where I heard or read it, but as I understand it, the active ingredient in a bottle of epilame is extremely small and more than 99% of the contents of the bottle is just a transfer agent. If the active ingredient becomes too concentrated, which it can become over time, or if the product is of poor quality, the oleophobic effect is amplified. This in turn causes the applied oil to look like a gummed-up ball on the surface of the treated part. If that happens, we know that the active ingredient has become too concentrated. What we want is for the oil to bind but not to the point where it is formed into an excessively round ball on the surface. The highlighted text in the patent that you refer to describes well the problem that can arise with too high a concentration of the active ingredient. However, I would be extremely surprised if the entire amount of oil leaves the treated surface as water on wax would. At present, I am convinced that the analogy between wax and water on the one hand and epilame and oil on the other is incorrect. Epilame is described as binding and that is also my absolute experience. Epilame probably has some repelling effect but that is not its main purpose and that is not how epilame is designed and works. The method of abrading the epilame treatment from the section of the pallet stones coming in contact with the escape wheel teeth seems after even more research to be well established, but if it actually works, if so how and why is beyond what I can currently understand. Perhaps it is just to do and trust that it is based on well-established experience. I am, after all, inclined to think so.
