Lubricants to use with Rolex 3135
37 minutes ago, rodabod said:
Slightly off-topic: has anyone ever tried Epilame on clock bushes? The oil does tend to creep due to gravity and natural spreading.
I know a guy who does, he does really high end restoration and custom fabrication though. He uses an eye dropper to dose the bushings, probably uses more in Fixodrop value that what most normal clock services would cost!
  • 8 months later...
Hey! It's Halloween, so lets resurrect an old thread!
Epilame- it's expensive. I was going to try and make some myself... Then I discovered this stuff:
"HOROTEC episurf-neo", which is supossed to be the same thing, but it's like 1/10th the cost.
Any comments on it?
Their website looks impressive so does the tech sheet. But can we really trust the product if it's this cheap obviously we should be suspicious.
Then the second link is being irritating because it's not letting me show you the link that I found so you go there in search for Epilame You'll see all the supplies to go with your inexpensive product. Unfortunately no expensive products to compare to.
There isn't any reason why cheaper products especially if they're being sold as a watch product can't work. Then what was interesting is on another watch site and I was thinking it didn't look that inexpensive because their cost was basically twice what is costs here. I think the 50 mL bottle was close to $100. It's one of the interesting problems of online watch supply people that sometimes they're not always that she you need to shop around.
There isn't any reason why other products can't work just as well and conceivably be cheaper. Some of these products are used in industrial applications and they obviously can't be superexpensive.
What would be an interesting experiment to try would be to do it the old-fashioned way sort of. The original product is stearic acid and I read a patent once about vapor application was very very good. There is a cleaning machine out there that's name I can't remember that it actually vaporize stearic acid for applying it to the watch parts. Supposedly with the vapor you get a really thin even coding versus the fluids that if you're not careful they evaporate with time and the concentration changes and you can end up with a thicker coating than you want that may be bad but I don't know how but. I is know I've met people to get really excited about how it's all applied heated treated etc. and dropping apart into the bottle itself is a total sin even though that's a convenient way to do it.
https://www.surfactis.com/en/produits/episurf-2/
https://www.jewelerssupplies.com
Yes, I was looking into (and found a reasonable cost small sample picked out) of Steric acid. The only issue I want resolved is the carrier, and then the concentration in solution.
I want to avoid alcohol, as it would limit use on pallet forks. I believe it is water soluble but that’s not an ideal solvent for steel parts. Acetone may work but I’m not certain. Toluene is on the list too.
The $100 bottle for applying it is another hurdle; but I’ve been working on that and may have a lower cost solution. I know another member here was also working on a home made bottle but I never saw how that turned out. I was thinking a second bottle would be good for dilute oil for reversers too.
I have one of the machines John mentioned above that heats the stearic acid to make a vapor. It works great, but I do in practice use Fixodrop on customer watches. If you want to try the vapor method it just needs to be heated to about 80 degrees C, with the parts in a basket or something not in contact with it, in a container that can be closed. 30 to 60 seconds is enough time.
The first liquid epilame that Moebius marketed was Aretol, which was stearic acid in a solvent carrier. I don't know what the solvent was, but it wasn't alcohol. I have spoken to old watchmakers who mixed their own using pure isopropyl alcohol (99%) mixing 1:100 by weight. I have tried that and find that it leaves a visible film, didn't follow up with different ratios as I have the vapor method and Fixodrop. But if you try it with alcohol don't worry about it melting your shellac, it only needs to be in contact a few seconds. In fact the above machine, the Greiner U2, uses alcohol as the rinse for all the parts. The way it is designed the balance and fork get rinsed by themselves for a short time in fresh alcohol (it distills the alcohol continuously), then dried as the other parts get rinsed and the rinse is drained back into the distiller then regenerates for the final rinse. It's a very cool machine.
I can heat some on a hot plate and see how it does.
I have sample panels of cold rolled steel and titanium I can mess around with, to see how an oil drop holds shape over time.
I think I'll order the acid and play around with it a bit. It seems I have some time as the new oil I ordered has been a week in transit with no expected deliver date... Something up with FedEx lately.
  • 2 months later...
as it would be astronomically expensive to dip your clock plates in you could brush it on. Brush it on both sides of where the pivot goes. Then follow up with a piece of peg wood to clear out the hole and may be just a tiny bit of the countersink. I think that would work it would keep your oil word supposed to be.
Someone had asked about Epilame coating (from ye old Rolex service bulletin):
And I have yet to try mine. I will do on the 565 I need that damn spring replaced and then I'll do the usual suspects and see how it does (Episurf Neo).
I also bought two of the $100 German bottles (for much les than $100 for the pair) out of Germany, but they are being transported via mule team, and they aren't good swimmers at all... Still need screens, but I'm less concerned with that. One will be for Epilame and the other will be for Lubretta.
I thought I posted here and my question disappeared for some reason ? Anyway, thanks Tudor. I hope my Fixodrop will arrive shortly and then I can service my Rolex Submariner. I don't have the specialty bottle but I'll try to improvise something.
    • Sorry to jump in here, but I didn't want to start a new thread when there's already one regarding the second hand watch market. Can anyone tell me what I should be looking at when buying watches from eBay? I see loads on there for quite cheap, but after reading this thread I'm guessing they're all garbage and not worth the time? I recently bought an old Elco watch for 99p, just to practice on. I'm also really fond of the look of Services watches and Smiths Empire watches. I keep seeing them listed for around 5 or 6 pounds. Are they not worth the time buying? I'm not looking to sell watches to make a profit. I just want to buy watches I like the look of and wear them, but I also don't want to buy things that are going to be impossible to find parts for, or that have already been abused by someone else and broken beyond repair. Any tips?
    • I tried the Moebius 9415 from any sensible amount, down to microscopic a drop (or "super minimalistic"); the size of droplet which makes you really wonder why one would/should apply anything at all? But to no avail, consistently a lower amplitude compared to my Dr.Tillwich 1-3. Of course, as John mentioned above, the Dr.Tillwich 1-3, just like the Moebius 9010, likes to go somewhere else. Since short however, I'm the (proud?) owner of a bottle of Moebius Fixodrop. Can't say that I'm a proud owner of the 9415. So far, I haven't seen or discovered the "magic" of the 9415. Meanwhile, Moebius 🤣 has my money though.........
    • I used to be quite active on The Lotus Forum when I owned my Esprit. I was there for so long, Bibs asked me to be a moderator. I'm not sure how long I did that for, but I think I turned into the second longest serving moderator. When I 'handed back my keys', Bibs made me a Full Forum Member. Normally this is a paid membership. My reward I suppose for helping out for many years. Bibs (forum owner) is quite active on there and if I am not wrong, don't quote me in other words, I think he once said that the money from memberships didn't cover the running cost. He adds money himself to keep it going. Does Mark have any sort of subscription scheme on here? I'll admit that I never paid to be a member on TLF. I should have. I never did. I agree that it would be a good idea that there is some sort of contingency plan for this forum. I intend on becoming more active on here. Life has just been getting in the way recently. I enrolled on Mark's watch course and was keenly doing that, but even that has had to take a back seat for a while. I am looking forward to getting back into that and also starting to do work on the clocks that I have been amassing. To do that successfully, I see myself needing to lean on the other members here. If for whatever reason this forum was to close, I think a great many of us would struggle.
    • I think we are about there, if there were still lots out there then the cost of a watch from 5 years ago would be around the same as it is now (allowing for inflation). Given that the price has gone up several times over we can only assume that supply cannot keep up with demand so we must be at or past peak supply, especially if the trend continues. I see even places like Australia, Ukraine and even South America are selling watches on eBay, picking over their stocks, mixed in with fakes and Frankenwatches etc.
    • I understand the demand bit, the generation below me 30ish are too technology engrossed to own a mechanical watch and they just dont like old stuff. I also consider myself at the getting on age of 57 to be a rare find of someone that likes old stuff, i did buy an almost 100 year old book yesterday titled " The New Modern Home " printed 1929.  Cost me a quid. What i was trying to work out is if we have reached a volume peak of watches being discovered hidden in the back of drawers.  Those watches that were hung onto until they entered the hands of the non sentimental generation.
