Hello From Beavercreek Ohio USA
butch5319
Hello.  My name is Don.  I'm new to watch collecting but my main interest is in watch repair.  I have watched quite a few of your video presentations, excellent job by the way.  I'm curious about your video setup.  I take a lot of photos as I'm disassembling a watch but it would be great to video the progression.  I have a strong back-round in music but a career as an Electronics Engineering Technologist.  I have been collecting and learning how to use watch repair tools for the last year.  I really enjoy the challenge and learning how the different movements work.  I purchased an online watch repair course that has helped a lot and I'm currently looking at your course.  A year ago I joined the NAWCC (National Association of Watch and Clock Collectors).  What a great group of people.  I have learned a lot from them and plan to remain a member.  I discovered that when people find out that you work on watches they all have batteries that need changing, bracelets that need sizing and cases that need cleaning and polishing.  Not the repair work I had in mind but it's all fun and enjoyable and goes with the territory.  Thanks so much for this forum and all the videos.
Don
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
    • No problem to replace the setting with the staking set. Press the new setting from inside, use flat face punch with hole. The punch must be wider than the setting, the hole to be as not to press at the stone, but only on the bush. Press by hand until the setting gets flush with the plate surface, so the punch must rest on it.
    • Yes, the arbor usually makes about 3 to 3.5 turns. But usually spring takes 2/3 to 3/4 of the free space in barrel, not 1/2, so take it for the calcullations. This way the change in torque is smaller. I have a picture for You, this one is little older, but no mater
