It's a real problem. Very few watch parts suppliers deal in cases other than for the fairly standard ETA 6497/8 ex-pocket watch movements (Hamilton, Panerai, etc.). I have a lovely Longines 280 movement  for which I've been trawling for a case for a long time - with no luck. I keep checking eBay for watches with duff movements but, in most cases, a duff movement is housed in a duff case!
I have one case for which I have no movement. I'd be happy to send it to you to see if it fits one of your movements - with no obligation if it doesn't...
Edited by WillFly
Thanks Will .... all very true.
I would like to take up your kind offer, at least let me pay the postage....... :)
I shall PM you my address.......
Keith
Oh, I remember that one. All the way from Italy if my memory serves me, nice case though!
Spot on, Geo - as I recall, it was you who drew my attention to it in the first instance. It's a lovely case, just not quite right for the 280 calibre. And I just can't find the calibre that it will fit. Sod's law!
  • 3 months later...
Hi All!
So I have been successful in getting an old Bulova 11AFC back to work. The dial is horrible and hands were very rusty but I cleaned it as well as I could. The movement was very clean and went back together easily. I am going to post photos later. I may have the dial restored and some new hands but not sure it is worth all that.
On another note. I purchased the three of the watches listed in the photo. Looking for suggestions on cases and casing alternatives?
Any thoughts or suggestions are welcomed.
Thanks,
Gary
Hi Gary, it's a big ask to find the correct cases for these movements, the chances of finding the correct ones is not great. If you are skilled enough and keen enough and have the equipment, you could get something close and machine to fit.
Being realistic, it is probably better just to use them for practicing on, and buy a complete watch that is in need of total refurbishment, that way you will have all the parts at minimum cost. :)
Geo's absolutely spot on here - the right cases are a bugger to find and, as we all know, most movements for sale are the result of the silver or gold cases being sold for scrap. I've been trying to find a case for my Longines 280 for a long time now - with no luck.
I know a watch casemaker who did some work on one of my Elgin railroad watches a couple of years ago. I contacted him to price up making a case for the Longines in stainless steel. £2,500. Mmm...
The irony is I have a case for a Longines cal. 30L - and can't find a movement for it! :pulling-hair-out:
There are 3 30Ls on the Bay at the moment - but they're either too expensive or not in good condition for the price.
My 280 movement is in beautiful condition - and cost me less than £50.
Will, have you already seen this one ?
http://www.ebay.com/itm/LONGINES-30L-original-mechanic-watch-movement-running-1351-/261711540602?pt=ES_Relojes_de_pulsera&hash=item3cef39317a
Edited by vaguras
Thank you for the thoughts and no loss they were intended to be practice movements. That said, I have mangled heat another mainspring on the one I really liked with the silver dial. Seems my weak areas are mainsprings, hair springs and keyless works.
On a good note the Girrard Perregeaux has been disassembled and oiled lightly and back together. In a 24 hour period though it is running a little fast, about a minute. A.)I'm grateful I put another one back together, yeah! B.) with little experience I'm not sure where to look for this fault. Any suggestions would be greatly appreciated?
Gary
Gary
Hi Gary, what fault are you referring to? If it's the "minute a day fast", you should be able to correct that by adjusting the regulator.
Geo- I will use the regulator to adjust. Is it normal to have to adjust the regulator? After a correct service should it have to be adjusted? My thought is the middle would be the optimal position? Is that unrealistic of a watch this age?
Thanks!
Gary
Hi Gary, when you purchase old watches you never know who has been at them. A lot of folk will tamper with the regulator to try and compensate for the watch behaving badly, when it should really get a full service. The bottom line is after a service it policy to check the rate and adjust as required.
Could this be something that fits the round movements  ? it's a nice stainless steel case . The diameter of the movement needs to be 26,5 or under . And from the dial to the center of the stem 1,7 mm . Have about 17 mm lugs . The crystal is a little yellow from age but that isn't a big expensive thing to replace . Yours if you want ?  Or someone else ??
Edited by rogart63
May be worth a trip to the watch fairs there are often big boxes full of broken watches and sometimes you get lucky. Another thing is looking at "steampunk" stuff. It is amazing what people are selling just for decoration. The only other place is of course the Bay. There is also a place on this forum to advertise for specific stuff.
Good luck,
Vic
    • You often see the term used on old watch part boxes.  Staffs for bracelet watches, timing washers for bracelet wstches etc.
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. I stopped when the generously applied diamond paste started to touch the rim of the balance wheel, which turned out to be with a seat thickness left of 0.1mm. Tapping the remainder of the staff out went easy and flawless. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
