Hello dear watch repairers.
I am working on a Bifora 910 manual wind movement.
The movement was cleaned and oiled yesterday and I have been testing the performance.
I noticed that when the watch is fully wound, the amplitude reaches somewhere above 300 and rate gets super high.
However after about 5 minutes, both amplitude and rate plunge to a very low state.
I thought mainspring was the reason so I took the barrel out, cleaned the mainspring and applied 8200 oil again only to get the similar result.
What do you think is the problem and what can be done??
I am always thankful for your help.
this is when fully wound
After 5 minutes
Have you cleaned the watch in a watch cleaner? If so did you take apart all the shock from the balance, if so have you put it back correctly? No oil on the pallet pivots.
I would say you have a hairspring issue. Looking at the first pic it is running incredibly fast. It might just be magnetised which causes the  coils of the HS to stick together. If is not magnetised if it was me I would remove the balance and clean in a degreaser and dry. Then re-lube the cap jewels. This type of fault is a matter of elimination.
6 hours ago, Nucejoe said:
Hi,   What happens if you rewind full after the drops?   Dose it pick up again?
Yes. It returns to the same state as first photo.
Yes. I cleaned the whole assembly and oiled cap jewels on both ends.
I should give another try. I will let you know the result. Thank you.
A little clarification you Cleaned the watch did you disassemble the watch when you cleaned it? Then the mainspring are you using a new mainspring or the old mainspring?
Then when the watch is fully wound up do you mean fully wound up as tight as you can get it or just wound up until it stops?
What was the watch doing before you took it apart and cleaned it?
Timing machine diagnostic is very useful but sometimes it's kind of like reading a crystal ball it's not always an exact science if we don't have the proper background knowledge of what's going on with the watch. For instance when it's wound up tight the machine Numerically says it's in beat but the dots don't look like they're in beat? Then visually when you were assembling the watch did you check to make sure the watch actually is in beat? When the balance wheel and pallet fork were out did you check for Back spin?
Also helpful for diagnostics is more than one position on the timing machine. The typically dial-up and dial down and at least one crown/pendant position. As this is a wristwatch crown down would be fine.
On 12/9/2018 at 6:59 PM, Watchtime said:
looking forward to what happened....
Hello. I've been busy all weekend and could allow myself some time to work on the movement.
I disassembled the upper/lower balance jewels, cleaned and oiled them again.
I think the graph is much better except for the fact that amplitude is still way low...
For this time I added more photos of timetesting. I had no idea that much more things were related to timekeeping!
**I want to know what is a back spin and how to check it please.
I'm being sidetracked with other projects I  thought I'd check in and see how you doing?
Then regarding the question of backspin this is a discussion group did you do a search to see if that term ever came up before? So one of the ways to tell if you gear train is free with the pallet fork removed balance wheel removed. You start to the wind the watch and with nothing to hold the gear train in place it will start to spin once it's spinning you stop winding. The momentum of the gear train will go past where the mainspring is powering it and the momentum will wind the mainspring a little bit backwards. Once it runs out of energy that back wound mainspring will pull the gear train back. So if you look very carefully you'll see the train come to a stop and then go back just a little bit. That's usually an indication that the gear train is incredibly free and you probably won't have a problem.
then minor problems with backspin it doesn't work with all watches. The link below has what I believe is your watch and looks like a spring is over the sweep second wheel? That might be enough to interfere with backspin.
Then for the pictures at the link below this doesn't appear to be a super high grade watch? At the very end of the article the timing machine results look horrible to be honest.
A minor note regarding timing machine results? Unfortunately we don't have cheap artificial intelligence yet so that we can build a timing machine that tells us in audio terms what's wrong with the watch. So the meeting of this is timing machines are kinda like a crystal ball, okay there actually better than a crystal ball they do work with scientific principles but interpreting the results sometimes is a little bit vague basically it just points us in a direction. Then it requires the user to use their eyes and skills to look at the physical watch which we can't do we rely on your pictures and we can only point you in a direction.
so the timing machine isn't going to give all the answers for instance? for instance the watch running when it's fully wound up super tight and shortly later crashes and burns timing machine is it going to help with fact. then isn't this interesting resting on the pivots it's running fine and everywhere else you lose a lot of amplitude? So you need to look very carefully at the balance pivots and the jewels. As her seems to be an issue with their balance wheel as far as the timing machine can tell.
Thanks John I have never noticed the backspin but will look for it now. :Bravo:
I think the key to these types of fault is when assembling is to check as you go. I always for instance check for free play and end shakes after assembling the train of wheels. When assembling the keyless side again I check all is well as I go. Finding something is wrong on the final test is annoying to say the least.
  • Similar Content
    • Hi, this is the first place I found when looking for advice so I hope someone could advise me.  Im completely new to touching watches but I’ve always wondered how they work.  I’ve bought a cheap movement, an ETA replica to take apart and rebuild.  Im thinking I’ll need some screwdrivers, tweezers, movement holder and a loop? My goal is just to have a go first and see if I enjoy it enough before buying more tools.  Do I buy cheap tools for now and get better quality tools later if I enjoy it like I think I will? or will the cheap tools be a pain and take some of the fun out of it?  With quality tools being relatively expensive I’m unsure what to buy.    Any advice would be greatly appreciated!
    • Yeah I have seen 44-56 documented for Elgin 18 size elsewhere. I have the style of gauge that's like a set of feeler gauges and I never noticed before today it is faintly stamped "Elgin". Pictured is the way I have been measuring. I am going to go to a larger jewel than the 42 that had been in there. I recently won an auction on a big set of Fitrite jewels all in the little bottles, to discover that the what's actually in the bottles bears no relation to the chart of sizes printed on the box. In most cases it seems to be all mixed so in fact I have about 24 little bottles and thousands of assorted jewels of all diameters and lengths, which is better than nothing. But since I don't have a micrometer with a table, measuring for the exact diameter will be a big job. Instead I will test a lot of them in the fork slot the same way I measure with the gauge. But this is still the next thing. I have to get the escapement to unlock first.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
