Rack and snail and cam question
transporter
Westminster 3 train clock, been a long project, question is, if I set the long lobe on the centre cam towards 12 and the locking plate locked for the hour chime and strike, at the hour strike position,  would I then have the snail cam with the 12 o’clock mark also facing the 12 o’clock position?
If this is correct then the chimes and strike should be in time am I correct? Apologies for question but I’m up against it with this one chaps, cheers .
The lobes/cams you are referring too are at different heights with the hour cam giving the highest lift triggering not only the full Westminster chime but creating a warning for the hour strike. The set up I use is I don't fit the hands until I know where the sequence of the clock is. I count the strikes ie 1/4,1/2,3/4 & full chime. When movement is in full Westminster chime mode it should then give the hour chime. Once happy with this then I fit the hour & minute hands to the appropriate hour.
Oldhippy is the best with these I am sure he will chime in soon.
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
    • No problem to replace the setting with the staking set. Press the new setting from inside, use flat face punch with hole. The punch must be wider than the setting, the hole to be as not to press at the stone, but only on the bush. Press by hand until the setting gets flush with the plate surface, so the punch must rest on it.
    • Yes, the arbor usually makes about 3 to 3.5 turns. But usually spring takes 2/3 to 3/4 of the free space in barrel, not 1/2, so take it for the calcullations. This way the change in torque is smaller. I have a picture for You, this one is little older, but no mater
    • I overhauled a ladies Rolex and noticed erratic performance so I stripped in down again and did fault finding. This is what I saw. The lower jewel (the one in the plate) is cracked and the hole is too big. Before discovering this, I stripped down and re-cleaned the main-plate (and parts) by hand with a fine natural fiber brush. I somehow missed the fault the first time and cannot understand how it was still running. Perhaps re-cleaning it dislodged some pieces of the jewel widening the hole? I don't know. Now I need to replace the jewel but don't have a Seitz tool. The Rolex part is 2130-0913 and the top and bottom are the same. The part comes complete in brass setting with KIF elastor spring and cap jewel. Note: I have never replaced a jewel. I do have a good vintage stacking set that I've used quite a bit.  Can I replace using a stacking set? Any suggestions would be greatly appreciated.
