Introduction
timewaster
Hello Everyone,
My name is Paul Written and I would like to say hello having recently joined the forum and signing up to Mark's Watch Repair course levels 1 & 2. The reason for starting my new hobby/interest was because I purchased a couple of replica watches and wanted to learn how to take them apart, clean and service them. Inspired by Mark's youtube service of a 3135 movement I decided to see how close the clone movement was to the real one. I had read that these replica movements tend to be 'dry' and often dirty. The one I am working on now was full of dirt and kept stopping. I am just waiting for a couple of screws to arrive as one ping off and I can'r find it all. Careful next time! At least my wife doesn't mind my new hobby as all the tools can be put away into a small box .
Paul
I've already been on my hands and knees looking for a screw or two. :biggrin:
Mark's videos are very inspiring and yes he does make them look effortless. The oiling techniques are tricky to master. Too little is better than too much.
I'm stripping down an Asian 2824-2 now taking lots of photos as I go and referencing the data chart for correct lubrication. I can't find the click spring...
    • You often see the term used on old watch part boxes.  Staffs for bracelet watches, timing washers for bracelet wstches etc.
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. I stopped when the generously applied diamond paste started to touch the rim of the balance wheel, which turned out to be with a seat thickness left of 0.1mm. Tapping the remainder of the staff out went easy and flawless. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
