Showing content with the highest reputation on 01/18/18 in all areas
  1. When fitting new stems to watches I use these tools :- Digital calipers, Fine grade diamond lap Wire cutter Pin vice Now for fitting. (1) Hold the stem in the pin vice and screw on the crown tightly by hand. (2) With the movement fitted correctly in the case, insert the stem until it locks in place. Now measure the gap between the case and the underside of the stem. In this case it is 2.16mm. (3) Subtract 0.2mm from this size and this will give the amount to remove from the stem. In this case it will be 1.96mm which will give 0.2mm clearance below the crown when fitted to the watch. (4) Now remove the crown from the stem and hold the stem very tightly in the pin vice, then place the pin vice and stem between the jaws of the digital calipers then zero the calipers. (5) Remove the calipers and without touching the zero button set them to minus 1.96mm. THEN RE-ZERO THE CALIPERS AT THIS LENGTH The wire cutters are now used cut off the excess thread leaving a small amount to be filed to the exact length. (6) All that is required now is to dress the stem with the diamond lap a little at a time until the calipers read zero. (7) Finally screw the crown on tightly and it should be ready to fit to the watch without further adjustment. I find that this method cuts down on trial and error. FOR SCREW DOWN CROWNS. A) Screw down the crown tightly onto the case without the stem and measure the distance nbetween the bottom of the crown and the case. B ) Screw the new stem tightly into the crown, then insert into the watch until it engages and locks into the movement. C) Press the crown down firmly as far as it will go and hold it there. D) Using the vernier callipers, measure the distance between the bottom of the crown and the case. E) Subtract the size determined in (D) from the size measured in (A) then subtract a further 0.15mm from this size. This is the amount to shorten the stem by. This should allow the crown to screw full home without compressing the stem too tightly between the movement and the inside of the crown. F) Cut the stem leaving it slightly longer than the size determined in (E), and dress down to size using the diamond lap and vernier callipers as described in the original post. G) Screw the crown onto the shortened stem and check fit and function, before using a tiny spot of Loctite 221 to secure. Click here to view the article
  2. Thanks I looked into it and there is a difference in the length.
  3. Hi all, I don't like Marblack etc..it's leaves a horrible carbon layer on the slate if put on to thickly, which does polish off when waxed..M&P used to make a slate blacking the best ever oil based. .As usual they stopped making it..Only way really is to rub down with wet and dry paper finishing off with the finest. As there is nothing else suitable, the Marblack should be used sparingly and rubbed off..Then as mentioned good old Black Boot Polish Kiwi, not the pound shop rubbish. build it up using the makeup remover (dry small round wipes) nicked from her indoors..5 or 6 thin coats is usually enough, let it dry and soak in for a good few hours next day ok, and then using the wipes slightly damp with a small bit of polish on shine it up in circular motions, it will come up a treat.. Here is one I did earlier.. if links are allowed.. Len
  4. 1 point
  5. Hi Anliv , I have a similar gold dial Pogue and agree about the feeling when wearing it . I remember wearing it on a job interview for good luck . Does yours have any water proof/resistance markings on the dial under the hands ?
