Showing content with the highest reputation on 08/20/17 in all areas
  1. Strong and quality for sure, but the tips folds easily when pressing hard, and is not even close to the shape needed to open case backs. I really recommend to avoid to work on watches using a Leatherman tool. The watch is made adequately for its cost and purpose. Damage depends on the person which has assaulted it and nothing else. To hold it steady you can cut two pieces of wood to go in between and around the lugs, and place in a vice. It is difficult to pry open a square back without leaving any marks, all depends by the blade and technique used. For example, you NEVER twist the tip, but simply go around until it pops.
  2. I would have a look at Michael Bolton's vids. He's on a Seiko forum. He's in the trade of abrasives so that side of things he knows a lot of and Is learning on restoring watch cases and bracelets. By no means an expert but you can appreciate the end results [emoji106] Sent from my Honor 5c
  3. Thats what Adrian sells. I trust his stock as it's new "rubber" rather than NOS that's been sitting around for who knows how long. Sent from my Honor 5c
  4. Thanks guys. just contacted them. will let you know !!
  5. Yes, Adrian is a great seller. Also Stefan at Schillachi61 and Vintageseiko4ever are a pleasure to deal, in my experience. Best regards Miguel Enviado desde mi SM-N910C mediante Tapatalk
  6. I've got one. It does. Sent from my iPhone using Tapatalk
  7. It could be magnetised which will make the watch run erratically because the hairspring coils will stick to each other & you will also get a low amplitude. The other issue could be a damaged hairspring caused by a slip when adjusting the regulator. Being only two years old I have my doubts it needs a service unless some dirt/grease has got into the hairspring. Good magnification will be most useful with this.
  8. I spent the day literally watching paint dry. I was using black lacquer to fill in the engraving on a pocket watch case to make it stand out. I will send pictures when it is finished. In the mean time I was looking for screwdriver sharpening stone holders on the net. The sticker shock was amazing. So i said to myself, "Self" your only watching paint dry, make your own, you have a sharpening stone and some wood. So I made this from scrap wood while watching paint dry. I'm happy with it & it cost nothing. It is perhaps not as pretty as Bergeon but they have enough money.
  9. This should put your mind at rest. Click on this link. http://members.iinet.net.au/~fotoplot/sdriver/sdriver.html
  10. Like others on here I don't restrict myself to just one set of screw drivers. I have one set ground to a thinner profile, and another set ground to a slightly fatter profile. I also have numerous screw drivers ground to extra thin and extra fat. As a rule I find that Swiss screw slots are thinner than Japanese, Quartz movements tend to have a few have extra fat slots, very old pocket watches seem to have extra thin slots. This sounds like an expensive investment in screw drivers but I have probably spent less on my multiple sets than many others have on just one as I have picked them up second hand and in job lots from all over the place. They are good quality, vintage, French or Swiss. They don't necessarily have the silkiest smooth ball bearing tops to them but they are perfectly functional. If you generally work on the same type of movements (pocket watch, or Japanese, or Russian for instance) then one set of screw drivers tailored to that specific family of watch movements is all you need. As for throwing away old blades it does seem a bit of a shame. Generally speaking all that is needed to bring a chipped blade back into trim is 5 minutes on a stone (or decent quality wet & dry paper on a sheet of glass, or your diamond stones). If you find that you are regularly suffering from chipped blades then it might well be worth exploring the possibility of adjusting the temper of the blades. If you get it right you not only get more resiliant blades which are less likely to scratch movement plates, but you also gain an understanding of heat treatments for steel on a macro or even micro scale. Useful stuff.
  11. Hi. When I first started in this hobby, I decided not to go cheap on the tools so bought really good quality tweezers and screwdrivers, etc. This leads me to my question on screwdrivers which is that as the screwdriver set I bought (there are 9 of them in a rotating holder) and came with multiple replacement blades for each size, I assumed then that when a blade chipped, I just junked it and put in a replacement blade, however due to my inexperience I found I was replacing them really often, and in fact soon had to order more of the smaller sizes so: 1). Is this the right approach, i.e., just junk any damaged blades and replace them with new ones and if not, why not considering how cheap the blades are? 2). If I should be sharpening them, can I use a diamond stone as I already have a set of these that i use in my furniture making hobby? I also have water stones - would these be better? 3). I watched a YouTube video yesterday from the AWCI, which stated that not only should a screwdriver be just the right width for the screw slot, it should never bottom out in the slot but rather sit just above it so that the screwdriver actually jams up against the slot walls, which will prevent it slipping out and damaging the screw and/or screw hole. Is this correct because I assumed that the screwdrivers, especially given how expensive they were, would be inherently designed like this? Does this mean that even replacement blades should be adjusted on a stone to assure that they do not bottom out, and what if some screws have shallower slots than others for a given width, should I then customize the screwdrivers to ensure the correct fit? I should mention that, although I'm getting better at it, I still have screwdrivers slipping out of the screw slots and wreaking havoc, well at least on my ego, if not the movement itself. Should you have any other advise regarding the maintenance of screwdrivers, I'd love to hear it. Thanks from sunny Edmonton, which is now being subjected to a plague of mosquitoes thanks to recent heavy rains. And we thought we were going to escape that pleasure this year!
