Revisiting an old hobby
AndyHull
10 minutes ago, AndyHull said:
Watch mechanisms of various sorts and variable quality turn up at auction fairly regularly. Generally these orphaned pieces are the result of some vandal melting the original case down for its scrap gold value. Surely a flogging offence if ever there was one.
I've see some re-cased in modern cases as wrist watches but this one steals the show in that regard.
Maybe we should start a thread for the best re-making of an old timepiece.
https://german242.com/en/touchon-gold-enamel-minute-repeater/
I think we should start a thread on removing junk from ebay.  We buy junk, rescue any usable parts and scrap the rest.  Save newbies from bad choices, it would only cost us a few pounds each.
Another mechanical time machine for you to admire. This time it comes from the Soyuz program and is the "Globus" indicator that flew on many USSR era (and later) flights.
This marvel of eletro-mechanical magic was originally driven by the onboard electromechanical clock, which CuriousMarc and his friends also examined in detail so in case you missed that series of videos, start here.
Edited by AndyHull
Marvel indeed.
Just come across this posting. Read from start to finish. Entertaining, amazing and so interesting. For a beginner like me, 13 month now, I'm now able to understand so much of what you have done, doing and preparing.  Well worth another read, me thinks.
Thank you
Ross
Edited by rossjackson01
grammar
Thank you
Ross
Just finished the re-read. Still agog.
So amazed that you can do replacement dials. Do you place (put) them onto equivalent brass dials? Not been able to figure it out. Could you explain (show). I can't do it, just interested. If it is too awkward, that's ok.
Thank you
Ross
There are a number complete threads on the subject of creating your own dials.
They go in to a lot of details.
You might like to take a look at this ->
This custom Seiko is one of my favourites ->
You might like this.
Several things come to mind: I watched machines "weaving " gold chains, the really fine ones, incredible.  "Dumb and intelligent machines " I read a link on here about the " American way of manufacture " , basically intelligent machines used by semi- skilled people.  Finally the word "sabotage " , French clogs are called sabots and were thrown into machinery by p@#sed of workers.
6 minutes ago, RichardHarris123 said:
Does it tell the time?
Define "tell the time".
It knits a scarf, one stitch per half hour, so it tells the time about as accurately as a sundial, so long as you are prepared to count stitches..
On the plus side, if you wait a year, it will have knitted you a 2m scarf.
Besides, if you want to know the time, you ask a police man.
Edited by AndyHull
  • Haha 2
  • 4 weeks later...
On 10/25/2018 at 3:18 PM, AndyHull said:
Another member of the class of 404RIMG0427.thumb.JPG.44109717802159fecbf0591d5a0c1628.JPG
This one might however prove a a little more challenging, owing to the invisible balance made, no doubt from pure, refined 100% "unobtanium".
A bit of a shame really as I like the vintage look of the thing. Oh well, you win some, you loose some. :biggrin:
Way back in 2018, I picked up the Newmark shown in the post above.
I've been keeping an eye out for a suitable "404 club" style donor with a balance for it. One recently showed up on ebay, so persistence paid off, eventually.
That of course is where the problems started.
The donor arrived and I harvested the balance, and it sort of ran, slightly. So I stripped down the donor, cleaned it all and fitted the balance. It ran a little better, but the donor had no sub-seconds wheel, so I then stripped down the original movement and cleaned it too. It still didn't run well.
The issue was traced to a loose shaft on the balance fork, so the balance fork was also harvested from the donor. It ran a lot better, but the hairspring was now causing problems, as it was sticky. I eventually resorted to degreasing it with acetone, as my usual trick of dipping these crude balances in lighter fluid didn't work.
Now it runs pretty well, if somewhat fast, so I'm going to leave it going to see if it makes it through the next 24hrs without any issues. If so, I'll regulate it and see if I can correct the beat error at the same time without wrecking the hairspring.
I'm also tempted to swap in the plate from the other movement as rather oddly it has something resembling Geneva stripes on it, Croydon stripes perhaps.
I'm now a bit of an expert on these somewhat agricultural movements. I can't say I'm impressed with the build quality, but they are quite easy to strip down and re-assemble. The balance is a little bit finicky to fit, and the hairspring is somewhat delicate. The least little disturbance tends to pull it out of alignment.
A new crystal was fitted, and a new navy blue Nato band is on its way for it, and then it can finally join the 404 club after an almost five year wait.
Edited by AndyHull
12 hours ago, rossjackson01 said:
Excuse my ignorance. What is meant by 404? I see the comment often.
Good question. There is an informal "club" of low cost watches. Anything that costs  £4.04 GBP or less (or a similar 404 of the local currency).
Its not to be taken too seriously, so the rules are a fairly flexible.
There is an entire thread on the subject, with some real surprises from the bargain bins of ebay and various flea markets and car boot sales around the world.
Obviously there are some specimens that start off looking pretty sorry for themselves at these low prices, but that's half the fun of it.
You can read all about the "404 club" here.
Edited by AndyHull
I'm about to try to match the lume colour on the hands of a "Montine" 17 jewel dress watch.
I'm not going to touch the lume on the dial, 'cos I don't want to ruin the dial, so I'm doing a few experiments with "dollar store" acrylic paints, my selection of cheap Chinese lumes and my date expired Westfalia lumes to see if I can get a close match with what is currently on the dial.
I could just mix up some shiny new lume, but it would probably look way too clean.
As a result of all of my messing about, the bench currently looks like Holywood's idea of what a nuclear spill would look like.
I'm getting some pretty interesting effects. The experiment consists of mixing up PVA wood glue with acrylic paints and various spooky looking powdered pigments.
I'm sure there are more important things I *should* be doing, but none of them appeal quite as much as messing around like a small kid with things that glow in the dark.
Edited by AndyHull
Now I'm pretty sure that 'aint right. The random panel pin in the works looks like a non factory fitted option.
Sadly however, the free scrap metal was not the only issue. In the course of removing it, I took off the balance, and sadly the top balance pivot is shot.
Oh well, the watch *looks* good, even if it wont be working any day soon.
Edited by AndyHull
    • Just picked this up earlier today. This find just about epitomizes vintage watch collecting for me and what really keeps me going. Hit 2 antique malls today and saw a couple of pieces at the first one but just nothing that I needed. At the second one saw a Accutron 218 but it was 20 minutes behind the actual time. These "malls" have numerous booths of a variety of sellers who likely go in once or twice a week. Considering that that watch should be within a couple of seconds a month, I figured it hadn't been phased so passed on that for now knowing it would need work to run correctly and the price tag. Then I found this Excelle in a display case. I never heard of the brand, but in was an auto and had a little heft. It turned out to be 40mm lug to lug, 35.3mm case width, and 12.3 mm thick. On the spiedel once size fits most flex band. At $10.80US with tax I immediately pulled the trigger with nothing to lose. Before pictures: I spent a nice 30 minutes taking it out of the case and running that through the ultra sonic replacing the crystal and gasket and recasing, but spent five minutes first getting it running close on the timegrapher. Had a new crystal already in stock. I probably could have sanbed and polished the old one, but for $3 there is nothing like a new acrylic that makes a watch pop, in my opinion. The caseback gasket was hardened and just glad it wasn't tar. Changed that as well. Here is the after Pic on a temp black strap while I decide on a leather or steel bracelet. An added bonus was doing some research and finding out the Elgin connection and the movement is a PUW 1563T which is German I am pretty sure and probably why it doesn't say Swiss made on the dial. This movement is supposed to have a hack feature and quickset date by pushing the crown. But neither of those complications seem to be working. Not sure if the stem is cut too short because there is no gap for the crown to move. Either way at some point will need to be serviced and check the keyless works to find out what is going on with the quickset and hack of the sweep second hand.
    • On the link that I posted, one of the watches has no crown and another has a crown that is not square to the case. Does a broken crown signify that the movement may be quite corroded, hence the stem has broken, and does the bent crown simply signify that the stem is bent? Unfortunately as the seller has a bid on the items, he is now reticent to prise the casebacks off in case he damages something. The seller did reply with this email though. Hi again Michael - brief descriptions; Oris x 2, dials and hands ok and they set ok and one I just wound and it has been running for a few of minutes as I write this response. Rocar, dial ok no crown. No name dial no good and can't pull crown out to set. Roma dial and hands ok, I think it is pin pallet movement. Unicorn, good dial and hands and plexiglass ok for age. All cases and plexiglasses show wear except as mentioned. I have no idea what movements are fitted or condition so please if you do consider bidding, please do so accordingly as I don't like to disappoint my customers - regards and thanks again for your interest - Jim
    • The incomplete Vertex DD is a new project to sort out.  The Seiko gen 1, is my favourite watch to wear and is my daily.
    • To be fair it was a beautiful 'bumper'.  But, there was some loose parts in the case.  Perhaps 'pig' was a bit excessive 😄.
