Revisiting an old hobby
I have a barometer on my work bench that needs a replacement glass.. Diameter 77mm, 2mm thickness. BUT a hole in dead centre. I can source a glass but drilling a hole dead centre without a mishap is high risk. Anyone encountered this dilemma or know where to purchase please give a heads up.
I've inherited a pendulum clock with a broken pallet (please see photo) & I'd be grateful for advice as to whether, & if so, how a repair could be effected. As adhesive - even if it were strong/durable enough - would slightly alter the pallet geometry, I was wondering if a suitably shaped brace could be spot welded to each side edge to effect a connection but could the pallet be cast iron & therefore likely to fracture?. Also, what terms should I use (e.g. descriptive of the type of pallet) in searching for a replacement online?
That’s a great video - thanks for posting it. Sometimes to look forward too when I start looking at the ladies watch movements I guess. Although it’ll be a while before I get my hands on anything high-end I suspect.
Just arrived today with the case a little worse for wear so will probably just polish it back to the steel
I must be going nuts !! I checked the parts list to get a part number and see that there is no screw shown. Only a rotor assembly. I checked the rotor I removed and the screw is part of the assembly. What a stupid error Regards to all, Dave
