6 hours ago, grsnovi said:
I only ever had the first two LP's but in the last 50 years I've become more familiar with them. Page and Plant were quite a pair. Plant and Krauss have been finishing there shows with 3 Zep tunes. Plant still has that voice.
He has yes, a lot dont. It goes as they get older.I was a big deep purple and whitesnake fan. David Coverdale had the most amazing voice when he was younger, even men went weak at the knees. Saw him in concert about ten years ago, it was terrible. 😥
34 minutes ago, Neverenoughwatches said:
it was terrible.
Like McCartney now... some ought to know when to hold 'em and know when to fold 'em.
I thought so as well and very true. His Glastonbury performance was pretty poor as was Rod Stewart's for the Queen. A good voice can only last so long. I thought this was a watch forum 😆
On a more related note G . How are you getting on with the repairing ?  Are you like the new scope, it should be making things much easier for you. I'm looking for another one. Something a bit more portable to move from bench to bench and for my missus to use as she is also is developing a keen interest and is rather good  with h/s. 😡
Edited by Neverenoughwatches
Ah the Gambler. You can be a dead ringer for Kenny Rodgers if you just let your hair grow out a bit 😉
Come on Gaz, give us a tune. 😀
Ahhhh. Just had Bet Midler on the radio. A beaut that definitely has not lost her amazing voice. ❤
  • Haha 2
On 5/21/2022 at 7:49 AM, Kalanag said:
Wow! A battery powered electronic demagnetizer for about 10 bucks! I look forward to your upcoming report. For me the open question is whether two AA-Batteries can create a magnetic field that is sufficient.
Well this thing is actually much simpler than it seems.
The two AA batteries power a small electric motor, the shaft of which has a magnet on it. This means that when you press the small power button on the back, a rapidly oscillating magnetic field is generated. It does actually work, though I'm not sure I would trust it with a very delicate movement. It also has the ability to power a quartz mechanism, using the induced magnetism in the coil. Again, I'm not sure this is necessarily a good idea, but is entertaining to watch the hands whizzing round. The circuitry inside the watch may not be very happy with the effect but the experimental subject I tried it with did survive the process.
Is it worth the money. Probably, since it cost next to nothing, but you could rig up something similar from spare parts very easily. It is pretty cheaply constructed however, so you might need to hide it if the posh customers appear. 😜
Edited by AndyHull
Apparently I've been contributing to its decline. I should probably take some time away.
Apparently ? 🤔 .  Its good to diverse some talks, it makes things more interesting. Everyone contributes in their own way. If you enjoy it thats all that matters isn't it ?
What do wifes understand ? They're from a different planet to us. Women are from Venus and men are from Mars.  This why my wife and I live separately . I have my own house, my wife has a nice flat and we have another house that we built between us. We each have our own money more importantly our own space. See each other three times a week, sometimes mine sometimes hers. We are both very happy with the situation its the perfect marriage. Good quality time together but not too often to get on each others nerves. 😉
4 hours ago, Kalanag said:
A rotating magnet! Solutions can be simpler than one can imagine. 🙃
A picture of the gubbins inside. Note the splodges of 5 minute epoxy and the foam blocks keeping everything together.
I would guess that is an old CD player motor, and the body of the thing is a re-purposed battery charger of some sort.
There are two LEDs on the front, presumably to indicate the state of the two batteries in the original battery charger design, but only one of them seems to be connected.
It does what it says it does, but a word of caution. If you place a watch on it without switching it on it becomes a watch magnetiser. Don't say you were not warned.
To use it successfully, switch it on listen for the motor spinning, then place the item to be demagnetised on top of the label on the top of the unit. Lift the item away slowly and place it well away from the unit. Then switch off the unit and put it some place where there is no risk of it magnetizing anything.
To test, or indeed scare the life out of a quartz watch, switch the unit on and place the watch on top of the unit. The second hand should whizz alarming round in a clockwise direction.
I would be a little cautious about the quartz watch party trick. The spinning magnets will be inducing an unknown amount of current in the coil of the watch, and this may not be very good for the thing. It will however most likely free up a stuck movement, so if you have nothing else to loose, give it a try.
If nothing else, it would make for an interesting party trick, but only at a particularly boring party. 😋
Edited by AndyHull
28 minutes ago, AndyHull said:
…If nothing else, it would make for an interesting party trick, but only at a particularly boring party. 😋
Years ago I attended a party where a magician showed his tricks. He brought my quite valuable wrist watch to an immediate stop by just tipping with his index finger on the crystal. I was impressed! Months later I found out that this trick is done with the help of an artificial finger tip which has a little but strong magnet inside. The magnet pulls the seconds hand up to the crystal and stops the watch by friction 😮💨
Edited by Kalanag
  • Haha 2
Could have been a very expensive mistake for him if it hadn't restarted or lifted the second hand off its post. 😆
Keeping with the somewhat rambling and completely off topic nature of this thread, I got a spare moment to work on my HiFi project. I started with the rebadged Akai R470 - Memorex SCT-88 tape deck.
This was a bit of a mess when it arrived. Both belts had gone, and the tape counter belt had reverted to a thick black non polymerized goop, which had to be removed before I could even think about fixing any of the other issues.
This is the ebay listing picture for comparison.
It also had a broken clip in the transport mechanism which caused some weird load and eject problems, but that was a relatively easy fix with some supeglue and baking soda. After a fair bit of cleaning and lubricating and some cosmetic work to make it look clean and presentable enough to sit in the living room,  it plays perfectly and looks almost new.
After a little effort, I can now sit and listen to some of the large collection of tapes we still have lying around.
Interestingly when I took a quick trawl round the local charity shops the other day, not a single one of them (and we have quite a few charity shops here), not one, had any cassette tapes.
CDs, VHS tapes, Mini-disks, 78s, LPs, 45s, you name it, they were there, but not a single cassette tape. Very strange.
I think I'll probably tackle the record deck next, then the amp. I'll keep you all posted with any progress I make.
Edited by AndyHull
1 hour ago, oldhippy said:
I have a Sony TA-F400 amp the front is all black but dirty and stained with spots. What is the best way of cleaning the dirt off.
Depends on what is the cause of the dirt. Generally if it is just from years of grubby fingerprints, I would start with some light solvent, like lighter fluid or perhaps hand sanitizer. Test the surface first to ensure you are not about to lift the lacquer and the lettering, or destroy the surface of for example acrylic panels.
Try to avoid anything abrasive, unless absolutely necessary.
The clear plastic panels on that cassette deck, and the metalwork on the lid got a good polishing with T-Cut, which is of course mildly abrasive. It works on watch crystals, and it worked fine on the acrylic panels and the paint work.
For black plastic, and black metallic cases you could also try some of the car dashboard products, but be careful as they often contain some kind of blackening agent, which may not be what you want on the front panel of an amp.
Looking at pictures on line of your amp, the front panel looks like black painted or anodised, brushed aluminium, maybe start with kitchen cleaning wipes, and if necessary some lighter fluid. Clean in good light, and wear rubber gloves so you don't have to remove all of your fingerprints at the end of the process.
Switch off and unplug obviously before you start.
I got some and the box...what do you do with the box?
I found a local dollar store where they sell these and too much other craft stuff, I call it sino-German. I stain and varnish them according to days taste and paint leftovers. In this case I also promptly shattered the glass and replaced with much stronger thin boards. So the baby lathe accessories can stay together in a decent manner.
Well I now appear to have a working display on my Hi Fi amp (aka my Yamaha DSP -A970 Digital Sound Field Processing Amplifier).
My cheap from China display works. There are however, still a couple of issues I need to resolve.
The original display has slightly different dimensions, so I am thinking of 3d printing an adaptor for it. It is currently fitted with one screw, some tape and a tie wrap. Its perfectly secure of course. Also the backlight supply needs wired to the original switched supply, as currently the backlight remains on, even when the amp goes in to standby.
I may also check the old display as it may only be a failed tungsten filament backlight that is making that unusable, in which case an LED or two might fix that, and I can re-fit the original with no 3d printed adaptor required.
Edited by AndyHull
I also picked up a job lot of chrome tapes for a few quid, principally because I didn't want to destroy any of our tapes while testing,  so I have just played through a rather well made bootleg of Pink Floyd - The Wall.
There was still a little wow and flutter to start with until all of the lubrication got to work, but now it sound perfect. Well as perfect as cassette decks can sound.
The amp is very nice, and the effects are actually quite convincing. It does full Dolby surround sound too. I have to be a little careful as the amp is easily capable of waking up the neighbours and they live about 100 yards away. 😋
Do you mean "Dobly", hehe.
    • Yes, the specific old tools do exist, but may be having one is not needed as they are not cheap, and also You will be able to do without it well enough. My advice will be to use regular depthing tool and adjust it for the exact distance between pallet fork and escape wheel bearings from the watch. Then remove the shellac from the pallet that now doesn't pass the ew teeth and move this pallet in. Then put the pallet fork and ew on the depthing tool and check how they lock. They should not lock when the pallet is in, but You will little by little move the pallet out and locking will appear. Then move just an idea out for reliable work and apply shellac, then check if things are still the same. You have to observe where the teeth fall on the pallets - it must be just a little below the edge between impulse and rest planes. Then You must check how everything behaves in the movement This Potence tool is so ingenious, but actually, the traditional way to do the things is much more simple. Arrange the parts not on the pillar plate, but on the cover plate. Only the central wheel will remain on the pillar plate, secured by the cannon pinion.
    • There is a tool that was made for setting up and adjusting escapements of full plate watches.  There were two styles, the picture below shows both of them.  The lower tool held a movement plate and the vertical pointed rods were adjusted to hold the unsupported pivots of the lever and escape wheel.  There was also a version of this tool that had 3 adjustable safety centres so that the balance pivot could be supported by the tool :  The other version I’m aware of is the Boynton’s Escapement Matching and Examining Tool came as a set of two or three clamps that gripped the watch plate and held the safety centres for the pivots : These do turn up on eBay from time to time.  For some escapement work, you can set up the parts in a regular depthing tool, with the centres set according to the distance between the corresponding pivot holes on the movement.  I hope this helps, Mark
    • Once you are aware of the problem, you can adjust as necessary. I have a couple of the Omega 10xx, and they are not my favourites. They seem a bit flimsy and not as solid as previous generation Omega. But I think that's true of a lot of movements from the 70-80s. For me, the 50-60s is the peak in watch movements, where the design criteria was quality, not saving the last penny.
