I have two pieces I would like some advice on. New to the forum, and am looking forward to the knowledge this group brings to the discussion. I have owned/own vintage pieces, and am considering these as projects. The first piece is a Cal 352 Ref. 2577/2520 in 18k. I’m very fearful of water damage and rust in the movement. Also, the dial seems to have some water damage as well. But please tell me if I’m wrong! https://imgur.com/a/YFBGUnb
The next piece is a good clean example. Not sure Ref. As I haven’t seen the movement. The issue is. Fairly bent lug. It seems to hold a spring bar in place, but if the case has any weakening or micro fractures I would be weary of purchase. https://imgur.com/a/pGHaATO
Thanks a lot!
It's all depending on your experience. If you are new to watches then pick a simpler/cheaper watch that will not result in expensive mistakes.
Couldn,t open the links.
Extent of water damage can only be guessed, untill all movement is stripped..
Should you like to post the pic on forum or if otherwise make available, so to get  more opinion
I hate to be the one to say this, water is a leukimia to movement., replating...,.etc
It will never bethe jewel it was before water, immediate cleaning helps a lot..In case of unavailability of immediate cleaning nor the back removal, depending on the qualiy inside the case, I would go as far as to recommend braking the crystal to place the watch under the sun light for evaporation..
Regards joe
Hello @Chefbengates! Welcome to the forum. You have two great time pieces there. I am partial to the Omega Seamaster Chronometer, so let's start there. I am including some screen shots of your photos for convenience of others that want to see the movement. Aside from oxidation on the plates, the stem and underneath the oscillating weight, and the oscillating weight bridge itself are areas where I see evidence of some corrosion--probably moisture coming into the case through the crown? How do the bumper springs look? The dial looks OK, but the condition of the movement leads me to think there might be some rust under the dial especially the keyless works. How is it winding and setting? I case back markings lets me know the watch has seen lots of hands, and someone replaced the original sweep hand and the crown. The watch is certainly worthy of getting a good cleaning and thorough inspection.
The Seamaster automatic is in better condition cosmetically, and I see the dial is re-done, and the small seconds hand and the crown have been replaced at some point. Straightening the lugs requires a professional with specific tools, and I had some proficient work done for one of my watches by someone. I could give you specifics if you're interested.
436213592_ScreenShot2018-10-15at10_41_54AM.png.968601adbd5dff8cabd7b1c8df5d412c.png652683580_ScreenShot2018-10-15at10_42_41AM.png.b92f95d434de3e4cb9a40845a83d3ef0.png
Edited by noirrac1j
That Turler-badged one is beatuful. Completely filthy, but doesn't look rusty. Those movements are not too hard to find, so I'd be more concerned about the dial which looks nice to me.
The second dial looks re-painted to me, and that's a non-no for me.
Water is a killer of movements especially if allowed to dry out over a long period.  I wish I could be as optimistic as rodabod regarding the Turner Omega, but I fear you will find some considerable damage when you strip it.  These bumper movements are up there with some of the best for time keeping, so I sincerely hope I am wrong about the possible damage.
Have a look at this, it will give you an idea of how to tackle the job:
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
