greetings
yankeedog
To all ye present greetings,
     I am an incorrigible tinkerer,I cant help it. I took apart my first watch when I was nine years old. Of course I could not put it back together, but my father, whose watch it was did not get angry.. he understood my curiosity . He was the same way. I have absolutely no training. I am in no way any kind of expert or authority on anything, but I do have more than a fair amount of mechanical aptitude and a decent command of the English language. I believe there is no such thing as a stupid question, especially when I am the one asking it.I look forward to exchanging opinions and experiences and information with you all.
Henry
  • Similar Content
    • This is a flying cutter, usual one. The cutter itself is shown in the pictures in the first message, it is made of broken tungsten carbide drill bit. I asure that all the angles of the cutter are as they should be. I have video - little older one - that I made when onse making the same kind of winding pinion for a Poljot 2200, which is even smaller than this one. It is not easy to see in the video, but the tool rest moves about 1mm towards the object in Y direction and then returns back untill cutter is rotating. Then the spindle is rotated one tooth ahead and everything repeated untill all teeth are cut.
    • After a bit further research could it possibly be an AS 970?
    • Latest project was a non-running ebay purchase with an FHF70 movement. I stripped and cleaned it, reassembled it, and got it running. So far so good, nothing damaged AFAIK.  I was oiling the top jewel on the balance (the one in the cock) which was a slightly unusual shock setting. I removed the spring (3 leaves) which was part of a chaton holding the cap jewel. This left the hole jewel behind which I retrieved with rodico and then lost it. I was taking it off the rodico, very gently as I thought, with tweezers, and then it just disappeared.  Fast forward a week, I got a donor movement, non-running, with the plan to just take the shock jewel that I’d lost. It was the same movement but had standard incabloc settings, and was steel rather than copper/brass.  I changed the cock and balance complete and it ran, not very well. I switched the lower jewel setting, cleaned and oiled both jewels and the replacement balance. Without the pallet fork the balance swings very nicely with a puff of air. With the fork in place, balance out, it flicks side to side nicely with power in the mainspring.  Put them together and it doesn’t run. The impulse jewel sits in the fork and it stops.      Any suggestions how I proceed? In case you didn’t follow that I have 2 FHF70 movements, nothing broken as far as I can tell, but mixing up the balance wheels and jewel settings results in a non runner.
    • Oh and this almost perfect third wheel pivot and slightly set mainspring  Ah ok yes i see what you mean, good idea. I'll try that if i fluff this one up. The image isn't great quality but i like the idea though.
    • Why cut the paper, cut a square around the image and grind to it.
