Timex Assortment #53 Display Case
JerseyMo
A few weeks back I spotted a unique display case from Timex history on Ebay.  Yes, it was the 1959 display case where a watch is dropped on and anvil to show how good the watches are shock proof.
Now what made this even better is that I already had the catalog page showing this case. So of course I had to buy it.  Main issue was that the mechanism that raised and lowered the watch was missing perhaps the most important part.  Which was the  part that would trip the lever.  With a little bit of consultation with a my watchmaker friend a plan was drawn up on how to make the missing part.  So with a bit of spring wire solder to a hex nut and some chain, the display is back in working order.   Now the next one on the grail list is a display that dips a watch in water to show they are water proof.
I love the display case - a great find. Looks like there are a few empty spaces to fill with vintage Timex watches to make the display complete. I have one old Timex that I would love to donate to the cause. Send me a PM and I mail it to you.  Oh, I do have the stem and it does  run.
Edited by JohnHutchins
Thanks for the offer but I do have all of the spots filled now.
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
    • No problem to replace the setting with the staking set. Press the new setting from inside, use flat face punch with hole. The punch must be wider than the setting, the hole to be as not to press at the stone, but only on the bush. Press by hand until the setting gets flush with the plate surface, so the punch must rest on it.
    • Yes, the arbor usually makes about 3 to 3.5 turns. But usually spring takes 2/3 to 3/4 of the free space in barrel, not 1/2, so take it for the calcullations. This way the change in torque is smaller. I have a picture for You, this one is little older, but no mater
