How to clean best old watchmaker collets that have a little surface rust and dirt. How do you maintain them generally so they do not rust in the long run ..
Thanks
Henry
Clean them with a brushing pad (on a rotary tool if there is stubborn dirt), then white petrol plus few drops of machine oil.
I have used the edge of a screwdriver very carefully on the threads, where there is lots of dirt and a fake metal cleaning pad does not work. Lots of oil though.
It works beautiful on threads. Green kitchen pad (no sponge) at the supermarket. Cousins also sells them in big sizes.
Bigger collets (5c) I spin the in the lathe and polish them with a red (medium) scotch-brite pad. Inside as well if I can get in there. Then I spray with aerosol Precision oil- sold for micrometers etc. it just sprays on and leaves a light film as it dries. Will not affect tolerances.
If the back side taper is rusty, I polish that by hand with the red pad. It is as critical as the bore so be careful. Any burrs get knocked down with a stone.
Threads are easily cleaned with a wire “tooth” brush. Stainless bristles are fine. But you can use brass. Spray threads with the oil too.
Some of the 5c collets have an internal thread for a work stop. These I clean with a bottle brush. Smaller bottle brushes can be used to clean inside the collets too. Small bores can be cleaned with brushes for cleaning baby straws etc. but lab supply places have tons of sizes and materials. You can also cut a slot in a dowel and slide the piece of red pad in there to polish the id of collets.
Edited by Tudor
The external surfaces of a collet are easily cleaned up, however the real issue (at least for watchmaker sized ones) is corrosion in the bore.  Obviously very difficult to get at mechanically.  You could use an appropriate sized bit of brass wire as a lap but then there's the potential to start changing the collet dimension or bell mouthing it.   Some of the rust removal solutions work really well, I would try a soak in them.  They should remove the rust and only and on the inside and out.
With the rust removed, the best idea is to take steps to prevent it.  Rust requires oxygen and water.   A great deal of the water that causes rust comes from condensate.   Getting a dehumidifier will make the biggest difference, and keep the room a constant temperature.  Most condensate falls of the the air when there is a temperature change  -i.e. dew.  The idea is to keep well away from the dew point. The other thing is keep all tools covered, in drawers etc.  It minimizes the amount of air around the tool and hence how much condensate there can be.  Keping things oiled can help.  Oil doesn't protect so much from direct water like condensate, but it does provide a temporary barrier from the air, air that contains both water and oxygen.
Last thought, the volume of iron oxide is many times that of steel, so if there is just a bit of rust on something, don't despair.  If the rust is light, you likely won't even be able to measure a dimension change
Edited by measuretwice
Just my 5 cents as a good oil to stop rust.
Many years ago I bought a bottle of Camellia Oil to stop my Japanese woodworking saws from rusting.
It is a very light oil that doesn't leave the item sticky.
The japanese used to use it for protecting their swords first and then when the swordsmiths turned to making woodworking tools it was used on these high quality tools.
I now use this oil on anything precision that I want to protect from rust.
This is the stuff
https://www.kriscutlery.com/other-weapons/camellia-oil-for-knves-swords-and-tools
Of course this only helps you after you have cleaned the items.
    • Search 'PCB carbide drill bits'. They come in sets of 10 or 50 and have 3.175mm tail. They are cheap rather than affordable. Using this drill bits has been discussed here many times - they are longer than needed and easy to break, so it is useful to practice sharpening hem and drilling some useless parts to gather some experience before real work.
    • I'm a newb who is a bit late to the party here. I've purchased a Horia movement holder clone. And I'm aware that the support pins for the SW500 chronograph jewels can be different sizes. I purchased 0.8mm pins with the holder. These were all that were available at the time. Will these be the right size? Can someone shed a little light on this for me please?
    • That looks fantastic! I'm obviously a little late to the party here. Can you tell me where you sourced the case that you used in this build?
    • If pivot shoulder almost touches the mainplate, you will see lower amplitude and free oscilation comes to stop quicker. Such touching can stop the watch. This caliber is based on FHF, I think. So some parts of a cheaper movement of same caliber might interchange.  Both observation point to pivot worn short, which support you suspect , "worn pivot".  The problem with pivots wear to this point is , though the watch runs, pivots can easily jump out of jewel holes in the event of shock, pivots are actually not touching the end stones.   Classic watch repair recommends staff replacement or elongating pivots. Non classic let's you flip the end stones to have the dome side of end stone facing the pivot end, this will somewhat or wholly  compensate for the wear.  Regs
    • This watch has a pin end mainspring. It's a blued steel spring and may be the original >100 year old part. As you can see, it is quite set. Can anyone suggest where I might be able to obtain such a spring today? Dimensions: Height: 140 Thickness: 010 Arbor diameter: 340 Barrel diameter 989 (1/100 mm)
