ETA 2836 runs and stops
Hello,
I recently got my hands on a used ETA 2836 movement from a Rado watch, I thought it would be a nice little project to get it to run again.
It is currently still inside the watch, but it has the following issue, it runs for mostly one minute, sometimes even up to 5 minutes, then it seems to get a lot of friction, and stops.
If it runs for one minute it stops in exactly the same place it started. If you give it a 'wiggle' it will run again for another minute.
I would like to know what this could be, and how I can fix it / what parts need replacement.
I am not very experienced in watch repair, so thats why I am asking for advice with the diagnosis.
I hope someone can point out what could be the issue!
Regards
Hi JJW, you should really introduce yourself first before asking questions.
It is impossible to say what the issue is until the movement has been removed from the movement and inspected. If it runs but stops then almost certainly it needs a strip down and service. During this process the fault (if any) will be found.
Oh my bad, I will make an effort into introducing myself later today.
My question was not, diagnose my movement and tell me exactly what is wrong with it, it was more asking for some general pointers on what could go wrong with these movements.
One thing I noticed that for a period of about 5 seconds where there is more friction, the movements makes a much more high pitch noise when ticking.
As I have already stated, it is not possible to give a definitive answer without a closer inspection. It seems to be binding on something ,could be lack of lubricant or just dirty. The movement will need to be removed from the case and inspected.
Since your brand watch is of some value, you should learn on something else before going to it without any experience or tools.
I've seen a few Rados on ebay which came from the Phillipines.
If you've bought one of those be prepared as they've usually lived a hard life and will need some work to get it running properly.
Good luck!
Anilv
    • No matter what I did, I could not get the amplitude more than 240 deg. At least there is 0.2 beat error and minus 1-2 s/d.  So, probably not the happy end I would have hoped for, but still I think the watch turned out quite nice. You be the judge of that. Thank you everyone for your help!
    • its used to lengthen or shorten the suspension spring from the front f the clock dial, this in turn will give regulation to the clock. Try inserting a pocket watch key or even better the double ended key for the clock into the small aperture on the dial at the top and turning it, you will see the suspension block either raise or lower. If it raises the clock will run faster if it lowers the clock will run slower
    • Grateful for info regarding the nature & function of the horizontal cog and the unit it's on top of in the picture. It meshes with a vertical cog (enclosed in the unit) on the arbour which is supported at its other end by the back plate of the dial unit to which it is not quite perpendicular...
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
