Hamilton Intra-Matic - Buren Cal, 1281
WillFly
I was very taken with an article in Mark's blog on a Hamilton Intra-Matic watch that he'd serviced - one with a Buren calibre 1281 micro-rotor movement. So - some days ago, I found one on the German, Ranfft "bidfun" auction database, put in the minimum bid - and came back from Devon today to find I'd been successful in my bid. (Even on holiday, "watchitis" continues apace...).
Lovely movement, and I'm looking forward to getting this one.
Excellent looking watch, very clean by the pic, and to me a unique type worth of your wonderful collection! Sometimes I think "watchitis" is not too bad when you find gems like that one! Way to go Will!...and welcome back from vacation!
Well, the watch arrived today - ticking away like a good auto should - and I've had it on test for two hours or so on the wrist. So far, keeping nice time. I've appended my own recent pic of the movement, which looks beautiful. I'm not a huge fan of automatic movements, mainly because the rotor obscures the details of the movement, though I do have Seiko and Mido autos, but this little micro-rotor is the bees knees. I wonder why they weren't as popular as the more conventional and larger rotor-driven movements. Perhaps the servicing was more of a problem - perhaps they aren't as efficient in maintaining a power reserve or they were more fragile. Who knows. Anyway, I love all 30 jewels of it!
Edited by WillFly
Hi Will,
Just turn the screw on the balance wheel, it is a cam that will do small adjustments with timing. Easy on it though!
I believe you were talking about that adjustment or maybe I misundestood?
Edited by bobm12
Good morning Will. I found this article http://people.timezone.com/library/archives/archives631988314105468750 on the the Buren microrotor movement that gives an excellent description of its workings.
In my previous answer regarding regulation I only mentioned the micro-adjustment for fast and slow. Having read this article, the screw furthest away from the balance pivot is for micro-adjustment of the beat.
Thanks for that, Geo - just read it, and a fascinating article it is. The breakdown he shows is of the early, 17-jewel model, and he mentions how he'd like to get his hands on the later, 30-jewel model - which is what I have. I'm going to copy the article into my watch file.
The thing that really attracted me to the Buren 1281 was just the sheer beauty of its design and looks - and it's even more interesting to see its technical description.
    • You often see the term used on old watch part boxes.  Staffs for bracelet watches, timing washers for bracelet wstches etc.
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. I stopped when the generously applied diamond paste started to touch the rim of the balance wheel, which turned out to be with a seat thickness left of 0.1mm. Tapping the remainder of the staff out went easy and flawless. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
