400 day clock pendulum spring.
ftwizard
I need to replace the pendulum spring (the one the balls hang on) on a 400 day clock. Does the new spring have to be exactly the same thickness, or can there be a bit of leeway.
If it is a wind up it is essential to have the right s/spring and the same goes for the length. Also the block that goes each side of the anchor (long stem) has to be in the correct position.  This book is the clockmakers/repairs bible when it comes to these clocks. A photo of the clock would be nice and one of the back plate.
The Horolovar 400-Day Clock Repair Guide 6th Edition By Charles Terwilliger
Can you give a good photo  of the back plate and the height and width of the plate and we can look it up in the book oldhippy mentioned above and give you the correct size wire. But that is only half the job fitting everything onto the new wire has got to be in the exact positions too as a few mm out can be the difference between it working or not
The spring is still in place, so I can measure it, but it’s such a small measurement, I wondered if it had to be exactly right, will one or two thou” either side matter that much?
Try and get it as close as you can. Any change in length and the clock will need regulating, to high = to fast, longer = to slow The clock also has a locking device so it still needs to be able to lock if moving with out kinking the s/spring. Make sure you don't bend the new spring
Thanks for the answers so far.
So, length wise, I can put it all back together exactly the same as it came out, no problem.
I just need to order the correct thickness. I've measured the existing one at 0.0020" would it matter if I bought a slightly thicker one, say 0.0025 or does it have to be precisely the same?
The reason being the measurement I take, may not be exactly right, being as it's such a small dimension.
If you can give us a good clear photo of the back plate sugggested by Tmuir, he will be able to look up the exact s/spring needed. Sorry I’m unable to do so as I no longer have my book.
It is essential that the spring is the correct thickness and the correct length. If you move away from the spec you will runout of adjustment. This book is a must for the 400 day clocks;
Okay. I'll do that tomorrow. Thanks.
That is what’s needed. I’ll tell you how the book works. Tmuir will look up Kundo, you have the designs of the back plate and the positions of all the holes which consist of the train wheel holes and the screw holes. It gives the s/spring the thickness and the position of the blocks and the length all in a diagram. So when it comes to fitting the new one you cut to length, line it up alongside the diagram fit the blocks in position. Fit into the clock and if all is well that’s it.
That looks like plate 1407H Kundo 4 ball midget clock circa 1965
Use 0.0022" (0.056mm) Horolovar you want.
Page 133  in the 10th edition if someone else wants to double check.
It should do 10 beats a minute when set correctly.
Make sure you mark out the exact dimensions and the placement of the parts on the spring, or you can buy a complete replacement unit '5F'
https://www.cousinsuk.com/product/kundo
Thank you so much for finding that information for me. Not only is it valuable data, but I've learnt a great deal also.
I'm going to get the spring material and rig it up myself. Simply because I've not done it before. I'll probably never do it again either.:)
Agree with oldhippy. I have repaired and serviced a lot of these 400 day clocks. Everything has to be as near perfect as possible for them to run. As oldhippy say very little lubrication is required. The suspension spring must be perfectly straight with no twists or kinks. It must also be in perfect beat or you will find it will only run for a few days. However I do like them a lot and the book I referred to in an earlier post is essential.
That's what's happening. How do I make sure it's in beat? I was just doing it by eye, didn't know it was so critical. I've only done watches up to now. Can I check it on the timegrapher?
Another couple of questions if you don't mind. Where are those measurements taken from i.e.. from the centre of the pivot to the top of the fork, or from the bottom of the plate to bottom of the fork. I've set it as stated and the amplitude seems very low at about 170.
What would be a fair amplitude for this clock? Before I fiddled with it, it was about 280.
What measurements are you referring too.
    • If you tend to be a little heavy handed then heres something that might help you to prevent cap jewel loses if you have some spare tweezers. File a round into each of the tips so you can grip a capstone or chaton while oiling or moving them around. Instead of filing along the length, angle file the tips first then file the rounds perpendicular to the angle. This way the tweezers wont get in the way of the oiler. Choose an angle that suits your natural hand grip position. The tweezers can now grip round parts on four sides Instead of two that often flip that part away.
    • I had noticed that video before.  He has a separate video for the reassembly. When he started the reassembly with using peg wood to oil a jewel I have to admit that I didn't watch much further. He also advocated not lubricating the center wheel arbor because the cannon pinion is friction fit. There is also a blog post (Adventures in Watchmaking, I think) that has a bit of info but not much at all with the oiling.
    • In view of the modern lubricants available, would you lubricate a clock movement differently today?
    • Yep thats the way it goes. The trick is to lead it into a false sense of security. Go through all the motions of ordering another one but dont actually click that final buy it now button, then stand up say " oh well at least I have another one on the way" .  It will pop its head out and shout " SUCKER ! " . They've done studies you know 60% of the time it works everytime.
    • Hi. I used to live in Tadcaster nor York , there for 40 yrs  moved Aberdeenshire as the place was falling apart.  If you need anything just ask the members on here are very good and patient.
