Non removable balance jewel?
Fred
Hi, I'm working on this Ronda 217 movement and I couldn't figure out how to take the jewel off the balance cock. Are these designed to be disposable?
Any idea how to clean and oil it properly?
Thanks alot
Thanks alot
That's a new one for me. It looks like it could screw off. However if not you will have to clean buy soaking in a dish with a de-greasing fluid and then agitate with a blower. Then dry & then lube with a auto oiler.
Thanks for the replies everyone.
I will try the unscrewing and see if its possible.
What I did is just clean in an ultrasonic and naphta and oiling it from inside which was very tricky because I couldn't figure out how to remove the hairspring from the balance cock.
I will look into it again.
Thanks alot
18 hours ago, Fred said:
That would be great if you could do it.
It's removable but i wouldn't do it. Found this balance so i took it apart. The jewel is one part . And there is no thread in there . In order to remove the balance i had to remove the arms . To clean just put complete part in ultrasonic bath. And oil the jewel from the inside.
DSC09671.thumb.JPG.786a01ac3ae5aacadcec8ebc61c39ac9.JPGDSC09670.thumb.JPG.cbade49aaaf8428cf02c62350a9305ea.JPGDSC09672.thumb.JPG.d2cb6048b606458561b0c87105a86452.JPGDSC09673.thumb.JPG.0aaf8a5cab24c57e6a39d93dbfedf300.JPG
Thank you Rogart63 for doing this. I'm gonna follow this procedure.
