Hi,
For the second course I understand the work is done on an ETA 6497 movement.  Does anyone know a watch that I might score on eBay fairly cheap so I'm using the same one as in the lessons?  I googled the movement and found a few new ones for sale (offrei and esslinger) at the $200-$250 range.
It'd be nice if that movement was used in an el-cheapo watch I can get on eBay, I'm just not sure how to find out what watches would have that particular movement in them.  Or does anyone have a recommendation of a movement I might find that is pretty similar, but cheaper to practice on than what I've found so far?
Thanks for any advice.
3 minutes ago, rogart63 said:
A unitas 6497  wouldn't that work. A Unitas 6310 or silimar is a nice movement that works fine as a starter movement?
Mark's course is based on the 6497. Altough all these can be very similar, I can understand the desire of using the same model as in the lessons. Beside, these large watches are enjoying a new youth with customization and their bold look.
Do a search on eBay for ST36 this is the Chinese version somewhere in the range of $30-$50 for the movement. If you watch marks video above you'll notice he does say he's using a clone version and that they work quite well. Then used ones on eBay the best price is if the seller doesn't list the model number. So usually listed as a Swiss pocket watch Ideally you want to buy one where there taken aback off and you can see that it's the proper movement. Which basically means you have to spend a lot of time searching on eBay but if you do You can get some really good prices it just takes time to find the cheap ones.
Look on ebay for Arnex pocketwatches. I have 5 of them, all with the similar 6498 movement and the only difference is that the subseconds hand is 90 degrees from the stem instead of 180 degrees.
Sent from my iPad using Tapatalk Pro
Look on ebay for Arnex pocketwatches. I have 5 of them, all with the similar 6498 movement and the only difference is that the subseconds hand is 90 degrees from the stem instead of 180 degrees. Some have a brass or gold plated mvt but most are steel.
Even when buying Arnex pocketwatches as I cautioned in my message above it's nice if you can see the movement. I purchased them without seeing the movement but there's a caution. Notice in the images I attached the name is right and it's a pocket watch but the movement is not. The clue is where the secondhand is. On the wrist watch movements it's a much higher up on the dial. So ideally you should see the movement but that pushes the price up you can usually guess not seeing the movement and pick these up cheaply. Then there are other Swiss pocket watch companies or names on pocket watch movements that would be suitable occasionally some of the's will have a slightly older generation movement but still there modern Swiss pocket watches great for learning with.
I did a buy it now on a ST36 movement, $32 shipped.  I'm excited to get to learn to strip down a watch and put it back together.  I've got about 20 watches sitting in bins waiting to be put in working order after I learn some basics.
Can you post the link or item ID? I couldn't find the mov.t alone that low on AliX. But buying an entire watch gets you something wearable or sellable after done playing :)
Item 173219804789  I went with the movement for now.  I saw a case that I liked, I'm bidding on too.  It looks a lot like an Ocean Crawler case.  I thought it would be fun to make my own mock Ocean Crawler if I can find a face that is similar.  Once I'm done learning how to strip the movement that is.
Item 173219804789
Can't find that one but found 112872442837 shipping from EU, which is great for me, but not for you from the US - saying face reveals that.
Maybe should get one case and many mov.s to swap in, LoL
Talking about  a genuine Swiss ETA/Unitas 6497, these are much harder to find used than a 6498 because the 8s were used in a bunch of similar, mass produced pocket watches with the stem at 3 o'clock during something like the 1950s-70s (As shown already) .  For your purpose, I don't know how a Chinese clone type 6497 movement would work (easy to find inexpensive), or a Swiss 6498.  Sorry for any info you might already know/be obvious, just getting my start here.
    • You're asking a pretty broad question and you didn't specify the machine but yes it's simple especially if you have the right machine. The question has problems but I'll take it as it is. Is it really that simple yes especially if you have the right machine. So in the video below he's making a screw and yes it really is that simple but pay attention to the machine it is not simple at all probably wasn't cheap but it is small it will probably fit in your garage. Unfortunately wouldn't fit in my garage as it's far too cluttered up with things. In the video he talks about making a screw and pay attention to the machine. The machine has lots and lots and lots of cutters and lots of things to do lots of machining all-in-one machine conceivably one step after another all programmable. If you look at his channel lots of CNC's stuff and there are several other videos related to this machine. He goes to the factory where they talk about it and show all the other machines they make in Switzerland.  I did look up the specifications the machine I don't recall the price it's not going to cut wheels I think it has a maximum diameter around 11 mm basically it's really good for making small diameter watch parts. Then in one of the other videos he goes to a factory that used to make parts with waterpowered machinery been in business for 100 years and everything they now make is made with CNC machines including this one. What was interesting with the factory photo was that when they make some parts they can put them on a optical comparator comparator compares with whatever the reference is and the machine can be programmed to adjust its cutting to make sure everything is actually being made to specifications. Oh and then somewhere in all of this there was at least one picture of a balance staff can't have a CNC Swiss machine without making balance staffs.   It would be really nice if we had pictures of the machine. Then yes if you look at the page for wheel cutting you can enter parameters and it will generate a G code but he left out things? Notice he has a picture of a complete wheel but the G code isn't making a complete wheel it's only cutting the gear teeth I don't see whereas the program for crossing out the spokes? Typically when you see people cutting gears once the teeth are cut most the time the spokes are cut by hand. Occasionally someone will mill them out but typically not with the program which seems strange if you have CNC capability for instance one of my friends fill it used to design assembly line equipment or things to make things. So his hobby was to continue to make tools to make things like clocks. Very interesting and clever clocks but his true fund was making the machines to make the clocks. Then machine is not controlled by G code like we would typically find today as the stepping motor controller he has was made a long time ago and the individual controllers used a textbased program. So the company had a editor you could write a program to cause each the stepping motors to do something. So basically once you figure out how to cut a gear he would just change the parameters for different size gears so here's an example of a gear as you can see we have the teeth and the spokes. Then we have a picture the machine which sucks because it would've been so much nicer if I could've taken a picture when it was cutting a gears so we can see things better. Then yes there is a worm gear stepping motor indexing this is a mini lathe and the indexing is at the end of the lathe head hiding. The basic operation of this machine would be brass sheet not cut to a specific diameter size not even round mounted on the machine. Then it turns and a milling cutter will cut the diameter. Then the gear would be cut with a gear cutter. The same mill cutter for the diameter although conceivably change the size I don't know but basically the same milling for cutting the outer diameter would be used to cut the spokes. I really can't remember how he did the center hole but whatever it was was very precise.
