Beat rate - balance or hairspring
What determines the beat rate the balance or the hairspring.
I have a movement (CattinC64C) which had a damaged h/s which I couln't sort, so I ordered a new balance complete.  The movement now runs very fast (even when regulator is set at max -) and the timegrapher picks a beat rate of 19800 whereas the old balance showed 18000 so I guess this why it runs very fast..  If its the balance that determines the rate could I try using the h/s from the new balance on the old balance wheel?  Only a cheap movement so I don't want to spend any more money on it.
Occasionally the timing machine gets confused when it's in the auto mode. So you need to set the machine to 18,000 and then see what happens. Then on not familiar with the company is this a pin lever watch? That conceivably might confuse the timing machine.
Picture would be nice the balance wheel with hairspring so we can see if it looks right.
Then there are some watches that actually came in different frequencies and I can't remember how the part number changed it might just been a letter but it would depend on the manufacture. So it's possible that you do have a 19,800 bph balance wheel. The other thing is if you put the hands on what are they doing are they running really fast?
Then both the balance wheel with its hairspring determine the frequency. Usually the hairspring is vibrated to a specific balance wheel. You can change the balance wheel characteristics like adding or removing weight but it usually has a minimal effect versus a different hairspring.
The train of wheels determines the actual beat rate, the balance wheel and hairspring regulate it. The old "coarse train" watches had fewer leaves on the escape wheel pinion and the corresponding 4th wheel, and ran at 14400bph. Then along came fine trains at 18000, and then beyond that 19800, 21200, etc....one thing that remains constant is the rotation of the 4th wheel, which is one revolution in one minute. If the beat is 18000, the escape wheel advances 5 teeth per second (3 in and 2 out),  with 15 teeth on the escape wheel itself, so a complete revolution every 3 seconds. This translates into a 20:1 gear ratio between the escape wheel and the 4th wheel, so if the escape wheel has 8 leaves, the 4th wheel needs 160 corresponding teeth. 19800, with the same configuration, would be 5.5 teeth on the escape wheel, not possible, so the leaves and teeth were increased (not sure of the exact numbers) to slow down the advancement of the 4th wheel to maintain one revolution per minute.
The hairspring is selected for each balance, and vibrated (length determined) to give the proper rate of 18000, 19800, or whatever. The screws make a HUGE difference as in hours a day if removed or added. The lighter the wheel the faster it spins, and of course heavier is slower. The screws are there for poise (balance), and in the case of split rim balances also temperature compensation. The screws should not be removed or changed in position unless you really want to mess with the compensation and poise. If it took more/heavier screws to bring a balance into proper poise and compensation, then a stronger hairspring was used to control the added weight.
Edited by khunter
Thanks guys for the responses.  It is a pin-lever movement with Roskopf canon on barrel, but I don,t have any suitable pics.  The original h/s was not flat and my attempts to sort basically ruined it, hence the new balance complete route!  The spec sheet indicates 18000 but the watch gains minutes a day when fully assembled with hands fitted, which seems to tally with timegrapher indicating 19800.  Checked everything and de-magnetised.  Balance wheel is a solid wheel without screws.  I had put it aside, but thought I would ask the questions anyway.  Will perhaps have another try later and maybe keep eye open for cheap used movement.
Edited by canthus
Is there perhaps some extra hairspring extending past the stud? If so you could try re-pinning it making it a bit longer. Otherwise with a solid balance there's not much adjustment possible.
I’m following with interest as I have recently asked a similar question regarding an AS2063 which gained much more even with regulator on maximum negative setting.
No HS damage and gear train seemed original. Only problem is the owner never saw it previously running to confirm it was a good watch.
For the AS 2063 It's a modern watch with the floating regulator. Conventional regulators with arms have limited range of regulation. Floating regulators have a much much bigger range of regulation if it goes beyond that you have something else going on is not a regulation problem. So then you have to look at the usual suspects which on a modern screwless balance wheel is something is wrong with the hairspring. Now what I mean by wrong I don't mean that it's been swamped it's always possible somebody swapped a hairspring in which case you're totally screwed and nothing can be done. So the usual hairspring problems are they hairspring isn't where it's supposed to be. In other words it's bumping into something it's rubbing on something the coils are stuck together. This is where you have to visually really lock and sometimes it's hard to see. This is where it becomes really nice to have a timing machine or the software that lets your computer be the timing machine. Because without that there are things that you may or may not be able to see but timing machine will give you a clue. It's also nice if you can listen to the watch amplification is nice. If they hairspring is bumping into something it makes a nice musical sound for instance.
Apologies for the delay in replying. I only just noticed this. I appreciate your time to reply and beginning to realise I definitely need a timegrapher. Converse to the as2063 problem I had (was running fast but not resolved) I also have an old Newmark which I just cannot get to run fast enough. Your comment about the spring swap has me thinking........
I may need t slightly shorten the spring and as a consequence adjust the beat
Thanks for the food for thought
Regards Deggsie
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
    • Sure! Some very accomplished repairers never use epilame! I have often wondered if it is worth the trouble. Not using epilame will shorten the service intervals though, but that could be better perhaps both for the owner and the repairer!? Speaking of oiling, I just read this: After WWII in the 1950s the first Synthetic Oils came on the market. Most watchmakers did not rush to use these oils since they were bad for business now that the watch serviced with Synthetic oil would not come back to him for service for another 5-7 years he would lose a lot of income. ~Ofrei.com   Anyway, I wouldn't be surprised if it would be more correct to think of epilame as a binder rather than a repellant. Until convinced otherwise that's how I will think of epilame.
    • I read that same article last night  H.  I think epilame is too much headache for me, sources aren't always accurate, some conflicting. Such is the GRAVITY of this situation, Is it ok if i just STICK  to a thixotropic oil 🤣
