Loose sub-dial hands Seiko 7A38
Pip
Hi all,
I've had lots of 7A28's and 7A38's apart before but not had this issue previously - two of the hands just do not seem to bind at all with the sub-dial posts. I can fit them, press them so they are sitting reasonably low to the dial, then just lift them off with tweezers. So far as I can tell nobody has been in this movement before and they seemed ok when I was given the watch. I've only had them off twice so I'm surprised they won't reinstall. I'm sure the 3 sub-hands are all identical but I'll have a good look under the microscope in a minute.  I was wondering if the calendar ring was getting in the way but I don't think it is (sitting nice and central and evenly viewable through each of the 3 sub dial holes, there's nowhere else for it to go).
Any ideas? Is it me mishandling them? I can see from the first pic below that the one on the right is slightly chewed, not bad enough for this though?
Thanks in advance.
Pip.
Pics of top and bottom below and pic of the bottom sub-dial (running seconds) pivot? stem? post? Not actually sure what that bit is properly referred to as.
....you could try some type of hole closing tool. Also a quick non intrusive fix: get a loupe, stretch a thin layer of rodico over the hole with your tweezers. (you will not be able to see the rodico with the naked eye) place over the pivot and seat. This will hold the hand on and work as a temporary fix until more permanent repairs can be made.
The left one looks a little damaged . Pressed them to far down?  Not you but the tinker that was there before?  Or coming from an other watch?  As they don't look the same on the back?
Edited by rogart63
Serviced a 7A28 yesterday. Having trouble setting the sub hands in the right position. Not like a normal 6138/39 where you could press the reset button and the hammer holds it in position . Get it right and then press it down it twist a little. And i have to take it off again and again to get it as perfect as i can. That could be a part of the problem? Lots of on and of can wear it out.
I’ve had a bit of on/off with previous services. These have been off once and after I put them on one fell off and one was loose! Might have been someone else’s efforts a long time ago, this was in a drawer for many years (allegedly). It was a complete non runner that I’m fixing up for someone I know. I’m attempting the pin vice later I think.
18 minutes ago, jdm said:
Like a Seitz? How do you do that?
You use a cup-shaped plunger with a larger inner circumference than the collet. You then lower the plunger onto the collet with light pressure and raise the micrometer gauge back until it meets resistance against the plunger. Now drop the micrometer gauge 5/100 at a time and press until the collet is a snug fit. Where possible, you repeatedly measure the hand collet on a hand gauge to confirm you’ve reached the correct size.
I’ve tried things like using a pin vice in the past, and it can crush the collet out of round and is a bit unpredictable.
    • Next is to drill the screwhole this then provides an anchor point so the bridge doesnt slip around while scribing the shape. A cork lid, a pin and a piece of gaffer tape ( 😅 ) keeps it all in place. The hole is measured from the broken part using a hand measuring gauge. Mark the hole, punch it and drill it off to size. The awkward bit is working out where the jumper should be and the detent positions.  I remember watching a youtuber a while back do this with dividers, so i dug out my old school compasses and improvised a little. This bridge only has one hole and to find the detent positions you need two points of reference, so i just worked the second point from one of the corners, hopefully its near enough. Then scribe in the jumper using the two detent positions ( wind and time set ) that were marked and a big picture of the complete spring to look at that helps to give you a feel of where the jumper should be.
    • Right now I'm making do with a similar micrometer (the one below is $45 shipped but you can find better deals) and a $20 stand. You do have to be excruciatingly careful measuring jewels, since there's no table, but if you don't have the $500 to throw around, it's a nice option.
    • As  I kid, I'd watch Godzilla stomping over buildings and cars and I'd think to myself: Tokyo is a really dangerous place to live... . Cool watch!!
    • Next one up an AS 554, looks like a bit more to this one. First job is to check thickness, most springs are somewhere between .3 and .4, this one measures .35, that matches in with the .4 spring steel i ordered. So for marking up a permanent marker comes in handy to colour up the steel to be marked later with a scriber once its dry. Bestfit provide the extra bit of info for the jumper spring that is missing.
    • Thanks again, Marc.  Super helpful. I was wondering what the hole was for, and now it makes perfect sense. With your help and the other members here, it looks like I'm good to go with my Seitz tool set. I had to order some replacement pushers, but with those, the set is complete and in good condition. Now, I need to figure out what tool to buy to measure jewels (amongst other watch-related parts). I had my eye on the JKA Feintaster micrometers, but people get crazy bidding on them for $400-600 USD. I was thinking of just a regular digital micrometer (Mitutoyo). Thoughts?  Mahalo. Frank
