Ronda (915) Battery Change
By watchweasol · Posted
Hi New. More of a get you out of a hole than a bodge. There is no substitute for a new coil. -
Hi Zannuto.it on the net have one got €16 . 40. From Italy ithink -
Hi and welcome to the forum.. I take it you have held the opposite end tight and the business end is just turning , yes. If so sounds much like stripped threads, the screws might need cutting out and a new bar and screw fitting . But as clockboy said pictures please it makes life just that bit easier. -
Hello and welcome to the forum. Attached a little reading TZIllustratedGlossary.pdf
