I disassembled a Hampden Pocket Watch and was removing the roller table when I noticed that the roller table has a built in lip where the balance is friction fit on. I was using the wrong technique thinking this was a conventional roller table. Now that i have it all apart, with a small twist in the balance, i need to cut the balance staff on my lathe. Here are the shots and the plan. Will update as i go along.f6147a2366a8d112ce0481928619f900.jpge71bf60fdcc8aefb503ec476e991c42f.jpgc0ea08af4341f98ae250b2ebdf5bef73.jpg9aa6c9d77ab9e9239d903d1c0ac2ac37.jpge7676805b805dac6e3164c99a9410f52.jpg19afd34867432d32cf871bd7870db592.jpgb0d18db1b7db09dab6eceae3b78e8b5f.jpg2fd63e90994a820f5a4af555b817f05e.jpg0036d97b3f6e7f733ee11f57d8d46ef9.jpg
Now need to measure the old part at it’s largest diameter and pick the piece of blued steel that i will use6373777cc089dbcedc3158862c1571bd.jpg
This is followed by getting the right collet for the job.b58b64f7ba3b5fb3edd8bcf7eb5ca385.jpgThen i need to fit the stock into the collet and measure about 1/2 inch for the cut off.72cd6e33a7c3d1650e994cbf04846e49.jpg
I then cut the piece that i will use and put it back into the collet and make sure it spins true. This is done bu taking a small piece of peg wood and riding it along the bottom of the stock until it has no wobble. I am then ready to cut it down to the first diameter.
I prep the stock and get ready to measure the first cut.
That sure is a different sort of roller-table setup. I'm not a huge fan of Hampdens, but they do have some nice pocket-watches. Since I only have a couple of them, I haven't bought the book that is available for them. That said, it might be more for collectors than watchmakers, so it may not have mentioned this design.
The images look good. I look forward to watching your progress. I have a 18s 23J Hampden Special Railway that needs to have a staff turned for it. You might just motivate me to sharpen some gravers and have at it. Thanks for sharing. Good luck.
Just need to dig in and start cutting. I don’t really like the design and the double roller: safety, just barely fits on the top of the staff.
I have often wondered why Hampton named their watches so close to Hamilton.  vin
Marketing angle. It is a nicely made piece. The roller table has a large diameter for an S12 movement. Also need to shellac the impulse jewel back on as it was lose so i removed it.
having worked on both, I find Hamilton superior.
  • jdm featured this topic
So in this step, I cut back the stock for the Roller Table; remember that the Balance Is also friction fit onto the roller table. I fit the table in by hand and left just enough diameter to friction fit the roller table.719b7f42cfd0b709fd3e74e300a632c6.jpg
Then I took the original part and placed it up against the new part to determine where the largest diameter ends and where the safety roller fits
The next step was finishing the upper pivot on the hair spring side. I measured the old balance staff pivot using my pivot gauge ruler.09e5765e49de2d2a1e26787707fa704b.jpgIt fit nicely into a .12 millimeter jewel hole. Then I worked on the pivot with a ruby stone to shave it down to .15 mm, leaving enough for the Jacot Tool burnishing and sizing.76a5d8156f3fef6b3704e262f4289309.jpgf91f3b44c1e47093d75e6ca8cd0b9e65.jpg778ab4ad0f01050b3aaf00385c953afd.jpgThe last job was to work the inside pivot a bit before cutting off the balance staff and reversing it in the lathe.7e01fcdc92596d440c96f26bd6737ff0.jpg
Again, my setup. Will finish the other pivot tomorrow. And then Jacot heaven.9dbd87cce9446222f5ad43566f93a4da.jpg4322a2453f1040697c94399ba21a5cce.jpg
Flipped the staff around in the lathe and started working on the other side 9684781528680c0adca46845b1f8b8e2.jpg
Once i finished the pivot, i started polishing it down to .15mm with a ruby stone.9ef2f06fd2d50df893761a2e0d1fd8b1.jpg
It is now ready for installing the table and Balance and then to the Jacot for final pivot work.
Oh, I also did a trial fit of the pivot on the movement; lower balance Jewel. Needs to go down in diameter.1793b5c6222901baa5ed5b84b102cd45.jpg
  • 11 months later...
I'll be happy to move this thread to "repair walkthrough" as it get completed with more detailed steps and pictures.
Flipped the staff around in the lathe and started working on the other side 9684781528680c0adca46845b1f8b8e2.jpg&key=477334afafb5e5d792f27537818a15be00c2d435848ac04cb6aa46732d0cf8f1
Once i finished the pivot, i started polishing it down to .15mm with a ruby stone.9ef2f06fd2d50df893761a2e0d1fd8b1.jpg&key=904e103a1e8be505a7b6cf381025e60e846041c05fdb72db4d088debf1d29be5
036b31949f5fb3f5ed622d6b537d107c.jpg&key=8626c2ae06583cfef9729da9a6fbb0c4bcce59000416ca62d935079c316751c7
Oh, I also did a trial fit of the pivot on the movement; lower balance Jewel. Needs to go down in diameter.1793b5c6222901baa5ed5b84b102cd45.jpg&key=00b5c040f87b5f2d9038bce0c6e73df2deed7b54bf9fd70d5e40909faef8b525
You should probably move it to watch repair howto
Sent from my GT-N5110 using Tapatalk
    • I'm sure it's the ancien. My measurements: A = 342. The slight bend in the pivot would make much less than a thousandth of a mm difference to this so I don't think 348 is plausible unless there has been significant wear on the pivots. B is hard to measure without first removing the balance wheel. I measured to the other side of the balance wheel as best I could (263) then subtracted the thickness of the wheel (69) to get 194. This could easily be three or four hundredths out, so 195 looks right. (196 could also be right.) J couldn't be measured. I did my best to measure where the balance wheel has been riveted on and got about 95, so 85 before riveting is plausible. (60 is not.) G again couldn't be measured without first removing the roller. I get 37 where the staff emerges from the roller so 41 at the other end of the taper seems plausible. (43 is also plausible to me.) K = 60. (Definitely larger than 55.)   I've never replaced a balance staff; it'll be a new adventure for me. I'll have to read up on how to maximise my chance of removing the old one without damaging the balance wheel without having access to a lathe. I also need to explore how to remove the roller without damaging it. I won't actually place an order until I've gone through the rest of the movement. With the number of issues I've already found, I'll be amazed if I don't have more surprises in store. There are some watch part suppliers in Australia but nothing like Cousins or Otto Frei or Jules Borel. AllTimeCo is fine for basic parts for modern watches: batteries, bands, some crowns, stems, seals, movements, some tools, etc., but not really anything for vintage watches. Australian Jewellers Supplies is similar. Cousins charges about £9 for shipping to Australia which is about AU$19 and not too bad (considering Australian parcel post is $11) but I still want to minimise the number of times I'm paying it. I need to explore other options closer to home. There may be something in Singapore or China that would have what I want and ship it faster/more economically.
    • Hi, I just finished the service of a Rolex 3135. Amplitude is great, 295 degrees horizontal after 2 hours and 280 after 12 hours. Vertical positions are 25 degrees down on those. I am however seeing a rate variation with temperature. I have 0 SPD on wrist, say 38 degrees and +7 SPD at 18 degrees room temperature. That equates to +0.35 SPD which is within spec I believe (+-0.5 SPD/ Deg C max). It just seems more than I would expect from such a high quality movement. To put that in context, I see similar rate variation with temperature for a Seiko 7S26. Just wondering what you guys see. Thanks, Steve.
    • For years I've done it the el-cheapo way (read: cleaning by hand). Bought a 2nd Elma S15(H) ultra-sonic, including proper cleaning-fluids (Elma WF Pro (cleaning) & Elma Suprol Pro (rinse)) and entered a complete different cleaning world. These cleaning fluids are none-water based and not that easy to obtain. Initially I bought these fluids in Germany "SKSONIC" (www.sksonic.de) but last year they stopped shipping international. Perhaps they resumed international shipping? You can always ask them. You could also ask @VWatchie, he lives "next-door". As for the fumes; I use the ultra-sonic in my garage, partly for the fumes, but more for our dog ...... he goes "bananas" when I switch on the ultra-sonic. Oh, next on your list (if you consider watch-repair as a long-time hobby), a Microscope (up to 50x is enough).  Pegwood leaves, observed under the microscope that is, whole tree-trunks behind 🫣 Ultra-sonic, in combination with proper cleaning fluids, takes care of the cleaning.
    • How do I remove the hairspring from an ETA? 2846. Balance  staff pivot is broken and I need to transfer the spring over to a new wheel. But the spring stud is not removable. It seems it almost looks like a snap ring at the top of the balance cock or am I missing something?
