How do I remove shock springs in Smiths Cal 0104
mikepilk
27 minutes ago, Gpsluvr said:
You almost got it. It is connected to the bar and creates a hinge so it won’t get lost. When you rotate the spring ccw to the gap, it will pop up, rotating on the bar.
Sent from my iPad using Tapatalk Pro
Thanks. Sounds like a better design than some (e.g. Seiko) that are only too keen to ping-off never to be seen again!
When parts fly away the problem is with the person that does the job, not the design.
Check my video showing Diashock installation technique using a carved toothpick.
That's the way I did it in the end - not that difficult on the larger ones on the balance. It's the smaller ones on the train that I struggled with.
It's not good engineering as they are relatively difficult to fit,  compared to the Kif, Incabloc, where you are less likely to lose them.
Maybe that Kif/Incabloc have enough patents to stop similar designs.
Small ones can be safely and cleaned together with the place.
It's not good engineering as they are relatively difficult to fit,  compared to the Kif, Incabloc, where you are less likely to lose them. Maybe that Kif/Incabloc have enough patents to stop similar designs.
Again, that's your opinion. But with millions (?) of units produced, Diashock is an excellent shock system which poses no problem when handled properly.
No it's not my opinion - one is a better engineering solution than the other.
  • Confused 1
You have to admit however, there is nothing like having a part fly away into oblivion, hearing the report of it's vicinity and successfully finding it with the broom. I don't think I have ever been closer to God and Jesus than when I decided to take up collecting and repairing as a hobby. "Thank you God ohh thank you Jesus" LOL...! Can I get an Amen..!?!?
Amen [emoji16]
Sent from my SM-T585 using Tapatalk
I would also like to add, however good or an expert one might be, it is inevitable that very fine parts will at some point go missing or ping away.(to be found or not) It is just the nature of the craft. We can lessen the events with due diligence and preparedness. With time and practice I have noticed a definite decrease of incidences in my own work. I also have a pull out "catch all" that has saved me time and heartbeats on many occasions. If you've never gone wide eyed, open mouthed gasping in horror at the floor, you're doing it wrong! LOL...!
10 hours ago, Pip said:
Amen brother! Although I have been known to use different words when the part has disappeared...
Yes indeed, depending on the piece I'm working on I usually just sob for awhile, curse my existence and then just move on after searching around on the floor for the better part of an hour like some crack fiend. LOL.....
You forgot to add, “while hoping my wife doesn’t come into the room and find me.” ????????
My skills are improving, but I still get careless and the occasional part pings off the table.
My first search is using a powerful torch
Then I uset a strong Neodinium magnet to sweep the area.
Finally, I empty the Dyson, and vacuum the hole desk, me, room and examine the contents.  The time I've wasted ......
Until I perfected the art (and realised a slighly soft surface helps a lot), I had problems with cap jewels - like playiing tiddly winks, and not being magnetic even harder to find.
We all loose parts from time to time. Good tweezers such as Dumont help and when dressing them; leave a slightly rough inner surface near the tip makes a big difference [emoji16]
44 minutes ago, digginstony said:
We all loose parts from time to time. Good tweezers such as Dumont help and when dressing them; leave a slightly rough inner surface near the tip makes a big difference emoji16.png
I've just this minute finished dressing my Dumont #2 with some medium wet and dry !
I removed the shock springs by turning them - I like them
Much easier than Diashock
Edited by mikepilk
    • Drat and double drat i was looking forward to the royalties on that idea.
    • Compression Spring Various Size. This might be helpful. I have watch furniture restorers and how they go about this problem, they inject glue underneath with a syringe and clamp it, leave over night. Next day remove clamp and it smooth. You could use an iron but be careful not to burn the wood.  https://www.ebay.co.uk/itm/265697329513?chn=ps&_ul=GB&var=565484998457&_trkparms=ispr%3D1&amdata=enc%3A1jd_-94ilTHWZLQ3PxHeC1A73&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&mkscid=101&itemid=565484998457_265697329513&targetid=1647205088320&device=c&mktype=pla&googleloc=1006662&poi=&campaignid=17206177401&mkgroupid=136851690655&rlsatarget=pla-1647205088320&abcId=9300866&merchantid=119334104&gad_source=1&gclid=Cj0KCQjwir2xBhC_ARIsAMTXk849TnBArEYdgv1DpHf_somCZYmB7ViqD3UtvNJJc_dn4kj0AFxBXngaArSAEALw_wcB
    • 🤣 i think your first statement is rather dramatic, but i will take it in good humour.  I think the thread speaks for itself John.  What we are aiming for and when i say we, thats not actually that many that have spoke up. Is to have a back up plan to keep members in touch in case the forum ever disappears. So in essence yes the group has maybe taken on a life of its own and would like to remain together forever ( 🤣 i can also be dramatic )  maybe more members need to give some input of how they feel about it or say they are just not that bothered.  Either way at least the question gets answered. Can i ask what the forum means to you and how you would feel without it ? Thats one answer Rich from one person, without knowing how others feel the thread was just a waste of time. Aw Rich are you saying you'd miss me ? I'm touched 🙂
