I made a video of me stumbling through The disassembly of a 1890 Henry Peck pocket watch. It needs a cleaning and a new mainspring. Tricky to take apart. This is part 1 of perhaps 2.
JD good of you to post a vid uncensored. I found myself shouting at the vid :D
How that cannon pinion came off without any residual damage is a miracle. I suggest you purchase a nice cannon pinion removing tool. However should be a real nice watch when finished.
I suffered a breakdown watching this.:D What a very lucky guy you were in not wrecking this movement.
For my health and sanity, I will skip part two.
clockboy I was doing the same:D
JD good of you to post a vid uncensored. I found myself shouting at the vid [emoji3]
I had absolutely no patience on Sunday and had to beat the thing up. There is really no indent to grab the cannon pinion: just a pipe. So not sure a tool would work. I don’t treat any of the other watches this way:)
I suffered a breakdown watching this.[emoji3] What a very lucky guy you were in not wrecking this movement.
clockboy I was doing the same[emoji3]
I knew that it was my most unprofessional moment: especially when the works dropped out while pounding the cannon pinion. I promise i will be a better professional with the second half. I was up till 3am the night before at my company Christmas party, and pooped. Nobody ain’t learning notten from this video. :)
What will be nice is when i start treating this peck with loving care and it pays me back by looking great and working accurately. The other peck is now im-peck-able
I bet the other Peck is s******g itself !!!!! LOL   I thought you were going to reach for a tyre lever.
Edited by Johnnie
To add to post
That is a funny reply. The other peck didn’t have the same cannon pinion issue and therefore was treated with kit gloves
Hi JD, I have had many disasters and expect many more. I am a novice and have messed up a few watches because my skills didn't match my enthusiasm. Best regards Johnnie
So far i have no messups and about 70 pocket watch cleanings and repairs. I have also made 2 balance staffs: one works perfectly and one is awaiting reassembly. I have also cleaned quit a few watches including repairing a seiko Pogue chono. I have also pressed in jewels and trued balance wheels. So i have done a lot in the 3 plus years i have been studying and performing watch repair. I would also consider myself an amateur but have not screwed up a single watch. This one simply dropped from lack of focus on my part: could have been the first screwup but the watch gods protected me:)
If you are an amateur or hobbyist be in the right frame of mind to undertake the task. People that make a living out of horology have to knuckle down and get on with it. One thing that helped me was to get up and walk around or undertake a different repair and this time of the year make sure the workshop was nice and warm.
The above is a lesson I have learnt, when I am struggling and frustrated I now leave it and have a cup of tea! When I go back to it things seem to fall into place.
I too have stepped back. But with limited time, I can't wait to long. I was super careful when I did the hairspring work on the other Peck and I know I will settle back for this one.
Sent from my GT-N5110 using Tapatalk
Update: so i cleaned the watch completely and replaced the mainspring with one that i had. Had to anneal the end and bend in over to catch the barrel hook.
I then examined the jewels and found one badly damaged jewel and two other cracked jewels (fix later). Then i noticed that a tooth on the center wheel was bent completely over. I wedged in a knife and was able to move the tooth back without breaking. Lots of work remaining on this old beast. ace756c4ee1d35edc733399da85ef60b.jpg2b82ba18c9b05932b34e98abdd83b778.jpg28582a65b02988990c01113aa38527b7.jpgace602ee70c175eabfde5ca0153267f8.jpgbdf2a66be48b2bd405786b458e12b299.jpg430ddb57fb199fa80f83c06eac2f08f0.jpg
BTW, I did manage to anneal an Elgin mainspring and fold the end over and and fit it into the Peck mainspring barrel. This was my first true mainspring mod work. Used an alcohol lamp and pliers. And I was very careful. I'm a bit pissed at the number broken jewels in this movement, but it is 1890 vintage
    • I'm sure it's the ancien. My measurements: A = 342. The slight bend in the pivot would make much less than a thousandth of a mm difference to this so I don't think 348 is plausible unless there has been significant wear on the pivots. B is hard to measure without first removing the balance wheel. I measured to the other side of the balance wheel as best I could (263) then subtracted the thickness of the wheel (69) to get 194. This could easily be three or four hundredths out, so 195 looks right. (196 could also be right.) J couldn't be measured. I did my best to measure where the balance wheel has been riveted on and got about 95, so 85 before riveting is plausible. (60 is not.) G again couldn't be measured without first removing the roller. I get 37 where the staff emerges from the roller so 41 at the other end of the taper seems plausible. (43 is also plausible to me.) K = 60. (Definitely larger than 55.)   I've never replaced a balance staff; it'll be a new adventure for me. I'll have to read up on how to maximise my chance of removing the old one without damaging the balance wheel without having access to a lathe. I also need to explore how to remove the roller without damaging it. I won't actually place an order until I've gone through the rest of the movement. With the number of issues I've already found, I'll be amazed if I don't have more surprises in store. There are some watch part suppliers in Australia but nothing like Cousins or Otto Frei or Jules Borel. AllTimeCo is fine for basic parts for modern watches: batteries, bands, some crowns, stems, seals, movements, some tools, etc., but not really anything for vintage watches. Australian Jewellers Supplies is similar. Cousins charges about £9 for shipping to Australia which is about AU$19 and not too bad (considering Australian parcel post is $11) but I still want to minimise the number of times I'm paying it. I need to explore other options closer to home. There may be something in Singapore or China that would have what I want and ship it faster/more economically.
    • Hi, I just finished the service of a Rolex 3135. Amplitude is great, 295 degrees horizontal after 2 hours and 280 after 12 hours. Vertical positions are 25 degrees down on those. I am however seeing a rate variation with temperature. I have 0 SPD on wrist, say 38 degrees and +7 SPD at 18 degrees room temperature. That equates to +0.35 SPD which is within spec I believe (+-0.5 SPD/ Deg C max). It just seems more than I would expect from such a high quality movement. To put that in context, I see similar rate variation with temperature for a Seiko 7S26. Just wondering what you guys see. Thanks, Steve.
    • For years I've done it the el-cheapo way (read: cleaning by hand). Bought a 2nd Elma S15(H) ultra-sonic, including proper cleaning-fluids (Elma WF Pro (cleaning) & Elma Suprol Pro (rinse)) and entered a complete different cleaning world. These cleaning fluids are none-water based and not that easy to obtain. Initially I bought these fluids in Germany "SKSONIC" (www.sksonic.de) but last year they stopped shipping international. Perhaps they resumed international shipping? You can always ask them. You could also ask @VWatchie, he lives "next-door". As for the fumes; I use the ultra-sonic in my garage, partly for the fumes, but more for our dog ...... he goes "bananas" when I switch on the ultra-sonic. Oh, next on your list (if you consider watch-repair as a long-time hobby), a Microscope (up to 50x is enough).  Pegwood leaves, observed under the microscope that is, whole tree-trunks behind 🫣 Ultra-sonic, in combination with proper cleaning fluids, takes care of the cleaning.
    • How do I remove the hairspring from an ETA? 2846. Balance  staff pivot is broken and I need to transfer the spring over to a new wheel. But the spring stud is not removable. It seems it almost looks like a snap ring at the top of the balance cock or am I missing something?
