Greetings from Canada
YuriyV
Hi Yuriy, There is lots of expert help here. I am also an amateur watch repairer (retired electronic engineer) Mark gives excellent tutorials and I have used Practical Watch Repairs by Donald de Carle for some years now. Good wishes with it all. Best regards, Mike. From UK.
Edited by ecodec
    • Back home...printing now.  Will report results
