Hi
Can anyone help me with this problem? I have a size 12 american pocket watch that has what appears to be the wrong screw in the nickle  barrel plate. I need to remove it. It won't turn left or right, the head doesn't protrude far enough to grab it with a pin vice.
13 hours ago, clockboy said:
i have not had a lot of luck with Alum. Can it be drilled out or is it too small. A picture could be helpful.
Are you making sure to heat the dissolved Alum powder?  Works best to keep it heated.  Ideal mixture is 4 tablespoons to a cup  of water.
Just an heads up, if you struggle to find Alum, then you can also use Vinegar, Malt vinegar works, and you don't have to heat it either.
