Seiko 5J22A Complete Service
Hunting through my cupboards I found my old Seiko Kentic "Auto Relay" that I purchased sometime in the 90s, when this was the latest cutting edge Quartz Watch on the market offered by Seiko.
It's been sitting for over a decade without use, and I decided to really push myself and, with the Lord's assistance, completely strip and service this watch.
So I tracked down the Tech Specs, and if you are thinking of embarking on servicing the 5J22 YOU WILL NEED THEM!! :)
So here they are:
5J22A.pdf
I will be using the part names from this document for this walkthrough, so download and print it out for you own sanity.  The parts in this movement are incredibly small, so much so that my camera had trouble focusing on them ... so part names will help you as much as the visuals aids for this service.
Once again, I've had no one to guide me on this, so this is the way "I" stripped the movement down, the correct factory procedure may, and probably does, differ from my way ... so I give a warning here: CONTINUE AT YOUR OWN RISK.
Disassembly
Unscrew the back cover and store the rubber gasket away safely.
With a 2.0mm Screwdriver, pry the Location Ring out with the slots provided in the plastic ring.
Remove the Oscillating Weight with a 1.20mm Screwdriver ... and this will be the driver you use on all further screws.
To remove the Stem, you need to have the Stem push all the way home, to move the Yoke into the correct position so you can depress the lever (Location shown in picture after I removed the movement to make it easier to see the spot where you push)
The movement should now come out of the case along with the internal Bezel Ring.
Remove the Hands
Remove the 7 screws for the Circuit Block Cover A, and the Rechargeable Battery Clamp
(Sorry referred to an older pic to so you the location of screws)
Remove the Insulator for Rechargeable Battery, and then the Battery itself.
Remove Circuit Block Cover A
Remove Circuit Block Cover D
Reference picture of Circuit Block Cover D
Remove Circuit Block Cover B
Reference picture of Circuit Block Cover B
Remove Oscillating Weight Bridge
Reference picture of Oscillating Weight Bridge
Remove Circuit Block Cover C
Reference picture of Circuit Block Cover C
NOTE: The pin with the yellow arrow pointing to it holds onto the Circuit Block very firmly.  Be CAREFULLY and GENTLE, as the Circuit Block can be easily damaged.
This is the angle of attack that I recommend. Coming in on an angle just in front of the Crystal Unit, and gently push upwards ... and I mean GENTLY.  Patience wins the day!
Remove the Intermediate Wheel for the Generating Rotor
Remove the Generating Coil Block (grasp with tweezers where indicated with yellow arrow)
Remove the Second Coil Block (grasp with tweezers where indicated with yellow arrow)
Remove the Hour and Minute Coil Block (grasp with tweezers where indicated with yellow arrow)
Remove the Train Wheel Bridge
Remove the Second Wheel and Pinion, the Third and Fourth Wheel
Remove the Intermediate Second Wheel
TIP: Next is this first of three sets of Stators and Rotors that make up this Quartz Movement.
Be sure to place all the Stators and Rotors into a piece of Rodico for safe keeping.
As shown below:
THESE PARTS ARE MAGNETIC AND WILL ATTRACT PARTICLES, SO DO NOT PUT INTO THE BASKET FOR CLEANING
Remove the Second Stator and Second Rotor
Remove the Minute Wheel and Pinion, Intermediate Minute Wheel, and Setting Wheel
Remove the Center Wheel and Pinion
Remove the Generating Stator and Generating Rotor
Remove the Setting Lever Spring
Remove the Yoke and Setting Lever
Note: Release tension on the Yoke Spring FIRST
Remove the Clutch Wheel and the First Intermediate Wheel for Calendar Corrector
Remove the Hour and Minute Stator and Hour and Minute Rotor
This side of the Main Plate is now finished ... time to flip it over and start on the Calendar Works
Remove the two screws indicated and remove the Hour Wheel Guard Spring, and the Date Dial Guard
Remove the Intermediate Date Driving Wheel
Remove the Intermediate Hour Wheel, and Hour Wheel
Remove the Date Dial
Remove the Day-Date Corrector Wheel, Second Intermediate Wheel for Calendar Corrector, Date Driving Wheel and Spring
Note the position of tension of the Date Driving Wheel Spring (bottom of page 9 in the Tech Specs)
Remove the Circuit Block Spacer
... and the disassembly is complete!
I started work on this rather late at night and took my time and studied each part before removing, making sure to document everything carefully.  So I'll clean the parts and begin reassembly fresh tomorrow.  I can see this one is really going to push my abilities, and I'm looking forward to tackling it and uploading the reassembly steps.
  • Like 5
Ok, back to work ...
Cleaning
I went through all the parts with a small compass to check if they were magnetized, as you don't want to put any parts that are magnetized into your cleaning machine.
Simply move the parts near to the East or West of the compass and see if the North or South moves to point to your part ... if it does you'll need to clean it by hand.
DO NOT WASH THE BATTERY, BATTERY INSULATOR, COIL BLOCK, CIRCUIT BLOCK ... I hope this is  obvious, but better to add the warning than not.
Rule of thumb, if in doubt, leave it out!
After going through all the parts here is what I had left.
All other parts, including the Plastic Parts, Stators and Rotors will be cleaned with a fresh piece of Rodico.
Assembly
Place the Circuit Block Spacer onto the Main Plate
Clean all the Stators and Rotors before you re-assembly them ... yes they are that small!!
Fit the Hour and Minute Stator, and Hour and Minute Rotor
Fit the Clutch Wheel and the First Intermediate Wheel for Calendar Corrector
Fit the Stem
Replace the Train Wheel Setting Lever, Yoke, Setting Lever, and Setting Lever Spring
Fit the Generating Stator and Generating Rotor, and also the Second Stator and Second Rotor
Next is the Train and Motion Work, it is by far the hardest part of the assembly.  It is all housed under one plastic bridge, so to make it easier here is a location chart.
First the Motion Work - Setting Wheel, Intermediate Minute Wheel, Minute Wheel and Pinion
Slide the Center Wheel and Pinion in the affix the Spacer
Then add the Train - Third Wheel and Pinion, Intermediate Second Wheel, Fourth Wheel and Pinion, Second Wheel and Pinion
Place the Train Bridge on and locate all the gears into their jewel holes.
Next steps are easy, but be careful and gentle
Fit the Coil Blocks - Generating Coil Block, Second Coil Block, Hour and Minute Coil Block
Then CAREFULLY fit the Circuit Block
Place the Oscillating Weight Bridge; but do not screw down.
Then fit the Circuit Block Cover B, and only fasten screws indicated by yellow arrows.
Place Circuit Block Cover D but do not fasten
Continue and fit Circuit Block Cover C, this one you can screw down ... sorry forgot to take a photo, but it's the only cover left
Now place the Circuit Block Cover A Cover on and fasten down all the screws
Remember to leave the Battery Screw out ... as shown in the picture below
Flip the movement over and fit the Hour Wheel, then the Intermediate Hour Wheel
NOTE: I pictured the Intermediate Hour Wheel upside down ... sorry about that.
Fit the Intermediate date Driving Wheel
Replace the Date Driving Wheel, and the Date Driving Wheel Spring (Note spring location)
Replace the Day-Date Corrector Wheel (See fitting instructions on Page 9 of Tech Specs)
Replace the Second Intermediate Wheel for Calendar Corrector
Place the Date Dial Guard on, fit the Hour Wheel Guard Spring, and fasten
Install the Battery, and then fit the Oscillating Weight
Fit the Dial and Hands
Case the movement back up ... and you're done!
Excellent work Lawson!
I have one question, any particular reason why the magnetized parts can't go in the cleaner? Thank you in advance.
They will attract any of fine metallic particles in your washing liquid, much like the old magnetized sump plugs in cars.
I see, thank you Lawson that makes sense. Therefore in a mechanical watch it should be demagnetized first before cleaning/servicing just for the same reasons! Excellent!
Lawson,  for a beginner you have done remarkably well,  another very interesting write-up.  With the very high cost of labour it probably would not be viable taking a Seiko kinetic to a repair shop as the cost would probably outweigh the value of the watch,  this is another advantage of being able to repair it yourself.
I have to agree with you there Autowind, assembly of the train gears inside that plastic "gearbox" was very challenging and time consuming: with nine pivot points to line up with the jewels.  It's interesting to see in Mark's Video, were he replaced that Generator Rotor in an updated Kinetic model, the Generator Rotor is now accessible without opening the gear train ... this is a HUGE advantage and improvement in design.  So the newer Kinetics would be worth repairing; but as for a similar job on the 5J22, you'd be looking at a complete strip and considerable dollars in labour to replace the same part.  It would be cheaper to buy a replacement movement for it, then to service, which is a real shame.
  • 1 year later...
  • 2 years later...
5J22A.pdf seems to be corrupted -- when I download it I get a zero-byte file.  Can anyone check on the integrity of the attachment?  thanks.
We can't fix that. Search the internet to download from another place.
  • 11 months later...
  • 3 years later...
  • Similar Content
    • I tried pushing to dome the washer in and had no success, but stuffing it full of o-ring gaskets worked much better than I expected. It takes some pressure but not as much as you might imagine, but it does take patience ... and a couple of dozen small gaskets. I used the pendant tube of a watch case to stuff the gaskets in as I didn't have a way to machine a tool to suit.
    • I can't answer your question, sorry, but you probably don't what to transfer the spring to a new wheel. Springs and wheels are paired ("vibrated" together) to get the right timing and transferring the spring to a new wheel is quite likely to see you minutes per day out with no way to correct it. Some may tell you to replace the balance staff, but if you're a beginner you're probably better off sourcing a replacement "balance complete" if you can: staff, roller, wheel and spring already assembled as a unit.
    • I'm sure it's the ancien. My measurements: A = 342. The slight bend in the pivot would make much less than a thousandth of a mm difference to this so I don't think 348 is plausible unless there has been significant wear on the pivots. B is hard to measure without first removing the balance wheel. I measured to the other side of the balance wheel as best I could (263) then subtracted the thickness of the wheel (69) to get 194. This could easily be three or four hundredths out, so 195 looks right. (196 could also be right.) J couldn't be measured. I did my best to measure where the balance wheel has been riveted on and got about 95, so 85 before riveting is plausible. (60 is not.) G again couldn't be measured without first removing the roller. I get 37 where the staff emerges from the roller so 41 at the other end of the taper seems plausible. (43 is also plausible to me.) K = 60. (Definitely larger than 55.)   I've never replaced a balance staff; it'll be a new adventure for me. I'll have to read up on how to maximise my chance of removing the old one without damaging the balance wheel without having access to a lathe. I also need to explore how to remove the roller without damaging it. I won't actually place an order until I've gone through the rest of the movement. With the number of issues I've already found, I'll be amazed if I don't have more surprises in store. There are some watch part suppliers in Australia but nothing like Cousins or Otto Frei or Jules Borel. AllTimeCo is fine for basic parts for modern watches: batteries, bands, some crowns, stems, seals, movements, some tools, etc., but not really anything for vintage watches. Australian Jewellers Supplies is similar. Cousins charges about £9 for shipping to Australia which is about AU$19 and not too bad (considering Australian parcel post is $11) but I still want to minimise the number of times I'm paying it. I need to explore other options closer to home. There may be something in Singapore or China that would have what I want and ship it faster/more economically.
    • Hi, I just finished the service of a Rolex 3135. Amplitude is great, 295 degrees horizontal after 2 hours and 280 after 12 hours. Vertical positions are 25 degrees down on those. I am however seeing a rate variation with temperature. I have 0 SPD on wrist, say 38 degrees and +7 SPD at 18 degrees room temperature. That equates to +0.35 SPD which is within spec I believe (+-0.5 SPD/ Deg C max). It just seems more than I would expect from such a high quality movement. To put that in context, I see similar rate variation with temperature for a Seiko 7S26. Just wondering what you guys see. Thanks, Steve.
    • For years I've done it the el-cheapo way (read: cleaning by hand). Bought a 2nd Elma S15(H) ultra-sonic, including proper cleaning-fluids (Elma WF Pro (cleaning) & Elma Suprol Pro (rinse)) and entered a complete different cleaning world. These cleaning fluids are none-water based and not that easy to obtain. Initially I bought these fluids in Germany "SKSONIC" (www.sksonic.de) but last year they stopped shipping international. Perhaps they resumed international shipping? You can always ask them. You could also ask @VWatchie, he lives "next-door". As for the fumes; I use the ultra-sonic in my garage, partly for the fumes, but more for our dog ...... he goes "bananas" when I switch on the ultra-sonic. Oh, next on your list (if you consider watch-repair as a long-time hobby), a Microscope (up to 50x is enough).  Pegwood leaves, observed under the microscope that is, whole tree-trunks behind 🫣 Ultra-sonic, in combination with proper cleaning fluids, takes care of the cleaning.
