Some problems seem to come in clusters. Currently I'm plagued by difficulties with hand setting. I'm mostly handling old and very old watches which may well be a factor. The most common issue is usually that after cleaning and sometimes re-luming hands, particularly minute hands, the hand is too slack a fit. This is even worse when it has been necessary to remove hands several times as a blunderer like myself sometimes has to do as he chases problems round in hopefully ever decreasing circles. I've been working on a couple of hunters recently which bring amplified problems compared to regular open faced watches. Getting all three hands to clear one another is one thing but getting them to do so when the very low profile crystal is fitted is another. A couple of times I've thought "this is impossible" and the amount of time I've spent on it is ridiculous. And of course the constant adjustment rapidly slackens off the fit to the point of non-fit.
I suppose the associated question is has anyone thought up a way of slightly decreasing the diameter of pipe-less hand apertures? One thing I've tried which is semi successful (one time only procedure) is to put a tiny drop of hypo glue on the hole from the back of the hand, then let it dry for a good long time, then prod a tiny hole in it followed by fitting the hand (and getting that right first time as you don't get a second chance without repeating the entire process.) This glue has a rubbery consistency when set which means it tends to act like a gasket/washer. What I really need is some anti-broaches...
Roy
Roy
I'd avoid glue on hands like the plague!
So, the orthodox way of fixing the problem: use the staking too with a concave punch to reduce the diameter of the tube. This should be followed by gentle broaching on the lathe to the size of the pivot or 1/10th smaller for the friction fit.
More practical, since most of us don't have a lathe, do a gentle tap on the staking tool after you double check the tube is not fractured. If it is, you'll either have to replace the tube or the entire hand.
I hope this helps.
Most of the minute hands don't have a tube!
Obviously glue is undesirable but once set it's pretty much rubber. And I just realised that most foils are far too big however there are a few in every pack that are "blind".
Roy
Roy
My bad, was thinking on the seconds hand which is what I've gotten messed up a few times [emoji12]
I haven't had the issue with the minute hand but the same applies to the punches to close holes. You may have a scan of the staking tool directions but if you don't I can look for mine. If should close enough for the hand to fit again.
Cheers!
Have used acrylic matt or satin varnish a couple of times with success. It goes into the gap and hardens. How it works in the long run i haven't tested. But a few years it's been running now without any problems.
Very very little on an oiler. And has to be waterbased as it's sucks in much better. I have used Vallejo paint.
But take care as you don't want it to go into the movement. or further down the wheels. I remove the residues with Rodico before putting on the second hand. A day after .
Have not used any sort of glue yet but i was thinking on dissolved shellack before. Dissolved in alcohol making a thick solution. It has a consistency like You described and the joint will suck it and wont flow around. Someone should give that a try :)
Thanks for the interesting solutions suggested. I too have tried lacquer in the past. "Glue" is obviously an alarm word where watches are concerned but by waiting for it to dry (24 hours to set completely in the case of hypo cement) its consistency is a bit like rubber.
In the case of hunters nothing works. I'm just about to withdraw a listing because nothing I can do will prevent the hands jhamming at some point in the 12 hour cycle. I give up. Anyone want a hunter for scrap?
Roy, if you're talking pocket watches here then I have turned a bush for a minute hand on the lathe using guidance from George Daniels' book. That was to fit a set of hands I bought from ebay where the hole turned out to be a very wierd shape.
No endorsements for any type of glue [emoji16]As jguitron has stated. This is the correct method to reduce the bore diameter of the hand. You can lightly use a hand broach afterwards if a lathe is unavailable. Another way of doing this is to use a pointed stake close to the bore and to make a small indentation, this will displace metal inward and grab but a concave stake is best. If you don't have a staking set. Use a cheap small flat headed screwdriver. File the head to a point so you can make small indentations to displace metal.
I think some of the problem is the OP is trying to apply modern watchmaking techniques ie.. fitting the hands in a true horizontal position. But as the OP has pointed out, the minute hand is pipeless. Oldtimers firstly, set the hands at 3 o'clock and not twelve as we would today. This achieved more accurate alignment and why wouldn't you, if the watch has no "Complications"
Dealing with the minute hand. After fitting (being pipeless) You can at the pivot end , gently rock the minute hand up and down using tweezers, without constantly removing the hand, until you reach the desired result.
Sent from my SM-T585 using Tapatalk
Thanks for the suggestions one and all.
To clear up an ambiguity, it's hunter wristwatches rather than the PWs that are driving me to distraction. The extremely low dome makes the tolerances for hand setting extremely critical (by my criteria at least). Added to the extreme fragility of mineral glass of this thin variety. I broke the last one a week ago and I'm on to a solitary UB example that I have left. Now the bezel has been on and off so many times I'm starting to fear for its fit too.
The first hunter I tried to tidy up had me scratching my head until I realised that the hands were rotating in the manner of a fairground ride. Bent pinion; that one's cooling its hands in a drawer.
The idea of notching the bore of the hand has occurred to me but I've yet to try it. I have just had a new asymmetrical crystal made for a Tiffany/Buren PW and refitting that minute hand is also now giving me trouble, having just cleaned and re-lumed it. As I mentioned, sometimes it's ever-decreasing but often ever-increasing when it's not just circles.
I don't usually give up, I just threaten myself and move on to ****ering up something else...
Roy
It depends on how the centre of the hand is constructed. For the hands with pipes a tiny squeeze with a pin vice and for the hands that just have a hole then a tiny tap with a closing punch. HOWEVER always put a brass /steel tapered pin in it,s centre before adjustments. This stops going out of round & gives you an idea of the amount of adjustment being achieved, Hands are very delicate so gently does it when adjusting. Using glue in my opinion is a very bad idea.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
