Beat Error and Positional Error
Excellent. Thank you. I knew the power differences in width and thickness, but I was trying to figure out an equivalent mathematically. Having it explained like that makes things much clearer.
Is the pallet fork aligned with the roller on the balance. Can you post photos how the pallet fork sits in relation to the escape wheel.
The 3930 is just the reference from GR who make these springs and the X after signifies it's for a auto. So from a google search. 1.45 is the height 7.0 is the size of barrel this will fit from the washer 0.075 is the thickness which is where the strength comes from 240 is the length which equate to running time The critical part is the strength. If you fit a stronger one i.e. 0.085 then the potential is the watch would run faster, especially as these are newer materials. Obviously the height is also significant and you can't fit a higher spring in the barrel, but going down 0.05mm won't make a difference.
Andy, thank you again for all your help. You are a true gent. I removed the winding stem in order to pop it into the case so I could play with the movement more easily while the dial and hands were still in place, but it appears the setting lever spring has sprung. So, unfortunately I need to address that before looking at anything else. If I might be so bold: I presume (given I know what everything else is) that the 3930 is the power rating? How do you know what a suitable rating is for a watch, how do you know 3591 (assuming that's the power) is correct for the Slava 2427? I just know it's 1.5 mm wide, 0.06mm thick (assuming my measurements were correct) and fits in a 7.0mm barrel. The magic art of knowing whether a thicker or less wide spring would be suitable is eluding me, the maths didn't turn out as I thought they would. Again, thank your for all your help thus far.
